sonicjet Posted March 6, 2008 Share Posted March 6, 2008 18x8 46mm offset with Pzero Nero tires. Lowered on Tein Basics. 1st to tell I know that that driver's side rear wheel gap is smaller then other 3 and front wheel sticking out more then other 3. So my consern is w/o rising the car what is the widest tire size that will fit into the wheel well? My current tires rub on some bumps. Only driver's side and only on outer edge of the tire. Link to comment Share on other sites More sharing options...
SubyDude555 Posted March 6, 2008 Share Posted March 6, 2008 7.5 is the widest you can run unless you roll your fenders. Link to comment Share on other sites More sharing options...
BlackHole Posted March 6, 2008 Share Posted March 6, 2008 18x8 46mm offset with Pzero Nero tires. Lowered on Tein Basics. 1st to tell I know that that driver's side rear wheel gap is smaller then other 3 and front wheel sticking out more then other 3. So my consern is w/o rising the car what is the widest tire size that will fit into the wheel well? My current tires rub on some bumps. Only driver's side and only on outer edge of the tire. If you have one wheel noticeably different than the others I'd figure out why before making changes. I'll disagree with SubyDude555 - I'm already running an 8" wheel with no problems, and know definitively that 8.5" rims will fit and clear just fine. 9" might fit if I use the right tires. It's not that simple to change since actual tire size varies from manufacturer to manufacturer even though the stated size may be the same. Measure the available clearance you have and look at the tire mfg's specs for each size tire. For example - I'm running 235/40 General UHPs on 18x8 +48 wheels with no stock suspension clearance issues of any kind. 245 Generals would fit ok, but 255s would likely rub. Kyle "BlackHole" Link to comment Share on other sites More sharing options...
JonLGT Posted March 6, 2008 Share Posted March 6, 2008 You could do 245s on a 8" but it will probably not look right depending on the tire. I would go with 235/35s. Link to comment Share on other sites More sharing options...
whitetiger Posted March 6, 2008 Share Posted March 6, 2008 I run 245's on a 8" wide rim and they look fine. no sidewall buldge. with the right offset, 245 is the widest you can run without a fender roll. 255 will need a fender roll Link to comment Share on other sites More sharing options...
Hanger Posted March 6, 2008 Share Posted March 6, 2008 245/35/18 hits the sweet spot on 18x8 ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
grimbeaver Posted March 6, 2008 Share Posted March 6, 2008 I run 245's on a 8" wide rim and they look fine. no sidewall buldge. with the right offset, 245 is the widest you can run without a fender roll. 255 will need a fender roll Yup ditto that. Just enough space on the inside and outside for me. Link to comment Share on other sites More sharing options...
team23jordan Posted March 7, 2008 Share Posted March 7, 2008 go with 235/40 Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
