boostsr20 Posted February 18, 2008 Share Posted February 18, 2008 Not really sure where to post this but I'll try here first. Recently we had a really bad rain (in the middle of winter) so alot of the roads were flooded (6" max standing water). I did my best to drive slowly through them but Something still got F'd up. Everytime I use the key fob to lock the doors the alarm/horn will go of in about 15 seconds. Happens everytime. Not sure what to do at this point. I hate leaving my car unlocked when I go in places. Link to comment Share on other sites More sharing options...
BrownBoy Posted February 19, 2008 Share Posted February 19, 2008 why don't you just lock it manually until you can sort it out? There is a keyhole on the driver's door... Link to comment Share on other sites More sharing options...
boostsr20 Posted February 19, 2008 Author Share Posted February 19, 2008 Still activates the alarm that way Link to comment Share on other sites More sharing options...
LongHiway Posted February 19, 2008 Share Posted February 19, 2008 I think, the alarm system will not turn on (arm) if, one of the doors / hood / trunk is "open". So, I'd say one of those switches is a likely culprit. If you have the upgraded alarm with the shock sensor, that could be messed up, I think it's under the hood and might be the first place to look. How to find which door is a trick. The hood and trunk should be the most accessable, the doors would be a PITA. Link to comment Share on other sites More sharing options...
GTTuner Posted February 19, 2008 Share Posted February 19, 2008 Behind the bumper cover, on the passenger side, are both the regular horns and the beeper for the keyless entry. You may have had water get into either the harness connectors or the actual horn/beeper. I would take down the bumper cover and inspect them for water intrusion. Also, there is a harness that runs along the bottom of the radiator support that may have sustained damage in the past and now the water is in there. Good luck, keep me posted. Paul Link to comment Share on other sites More sharing options...
boostsr20 Posted February 20, 2008 Author Share Posted February 20, 2008 Thanks alot for the help guys. I'll have to wait until the weather clears a bit to get it figured out. In the meantime I figured out that if I just hit the lock button again when the alarm comes on that it will not go off again afterwards. Link to comment Share on other sites More sharing options...
Danase Posted February 20, 2008 Share Posted February 20, 2008 I had a similar problem on my 2005 Impreza but sold it before getting it fixed. Link to comment Share on other sites More sharing options...
LongHiway Posted February 20, 2008 Share Posted February 20, 2008 Ah, I think you got closer than with all the advice. A door lock. Process of elimination you might just find which one. Link to comment Share on other sites More sharing options...
GTTuner Posted February 20, 2008 Share Posted February 20, 2008 It should have dried out by now. You might have a BIU or a keyless entry problem. If water was the main cause, clicking the remote twice would not make a difference.....just my speculation. Link to comment Share on other sites More sharing options...
CTATV Posted March 4, 2008 Share Posted March 4, 2008 i ran mine through a good 8 or 9 inches of water on some back roads for fun doing a little of my own brand of rally X and had no problems. sorry I dont have much to offer you in terms of fixing it but good luck to you, from all my work with atvs and other toys over the years I feel the pain of electrical issues. they are a PITA. Link to comment Share on other sites More sharing options...
