2.5gtbx_44 Posted February 11, 2008 Share Posted February 11, 2008 Hey I recently put on new wheels (18x8.5) with 245/40/18 on them. I am also running tein s-tech springs. Ive read and searched and have concluded that these wheels and tires should fit no problem but, I am having a rubbing issue. When I hit bumps at moderate to high speeds they rub. The backs more than the fronts but, they still rub. I was wondering if anyone else experienced this with s-techs and tire size or was it something I screwed up when I installed the springs?? Could my alignment be out of wack?? any input would be appreciated. Thanx in advance. Link to comment Share on other sites More sharing options...
JonLGT Posted February 11, 2008 Share Posted February 11, 2008 the tire size is too wide.Im assuming the offset is 48. Link to comment Share on other sites More sharing options...
whitetiger Posted February 11, 2008 Share Posted February 11, 2008 the rears usually rub on the rear fender. ther si s rubber strip on the fender that you can remove to gain some clearance. afther that, you will have to roll the fender and if that still wnt work, you may have to buy adjustable rear lower control arms to allow you to camber the rear in more to get clearance. For the fronts, again you may need to roll the fender or buy camber plates to camber the front in more for clearance. 245/40/18 is hard to run with out coilovers to get the clearances right. i run 245/40/17 and i barely clear my fenders, but i also have all the camber adjustability mods i listed above. what offset are your rims? if they are any lower than +48, you are gonna need to roll fenders at minimum. Link to comment Share on other sites More sharing options...
2.5gtbx_44 Posted February 12, 2008 Author Share Posted February 12, 2008 They're +47. Would I be better off getting 235/40/18s or just getting coilovers? Link to comment Share on other sites More sharing options...
JonLGT Posted February 12, 2008 Share Posted February 12, 2008 I am having rubbing issues up front with 235/40s up front with the same option. You could probably get away with rolling your rear fenders and not changing the height of the car. Link to comment Share on other sites More sharing options...
whitetiger Posted February 12, 2008 Share Posted February 12, 2008 with a +47 offset, i think you could def get away with just getting your fender rolled. Link to comment Share on other sites More sharing options...
devobuzz Posted February 12, 2008 Share Posted February 12, 2008 I'm hoping 245/40/17 on +48 will fit with iON springs????? Link to comment Share on other sites More sharing options...
whitetiger Posted February 13, 2008 Share Posted February 13, 2008 ^that fits with my coilovers Link to comment Share on other sites More sharing options...
fweasel Posted February 13, 2008 Share Posted February 13, 2008 The brand and model of tire can also play a role, not all 245 tires are the same width, at the tread or the tire's widest point. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
Mr. Cakes Posted February 13, 2008 Share Posted February 13, 2008 i have 18x8 +48 225/45/18 rolled fenders progress springs and i still rub a bit Link to comment Share on other sites More sharing options...
EL PAALO Posted February 14, 2008 Share Posted February 14, 2008 I realize you're in a shrek, so your stock size is taller than a regular lgt, but 245/35 18 clears much easier. If you aren't rolled, roll. Link to comment Share on other sites More sharing options...
