longislander1 Posted February 10, 2008 Share Posted February 10, 2008 When my wife (around 95-98lbs) sits in the passenger seat of my '08 2.5i Limited, the passenger airbag light keeps shifting between "on" and "off." Is there a certain weight limit for activating the airbag? Can I ask the dealer to just put the airbag function on all the time? It's rare that I'd be transporting kids in the front seat anyway. Any advice appreciated. Thanks. Link to comment Share on other sites More sharing options...
Bdubs Posted February 10, 2008 Share Posted February 10, 2008 The seat will break in after a while. Same thing was happening when I purchased my car. After about a year, I've noticed it doesn't do it at all anymore. Link to comment Share on other sites More sharing options...
gianspi Posted February 10, 2008 Share Posted February 10, 2008 That is quite odd--a sensor shouldn't need to break in. When I put a gallon of milk on my passenger seat the airbag is ON. Your seat's sensor may be defective. Either way, I would get that checked out. I think that it may have a lifetime warranty like the seatbelts do. enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
deeslk Posted February 10, 2008 Share Posted February 10, 2008 I would take it in, they probably need to adjust or replace the sensor, it should be on for half your wife weight. I think it is on around the 40lbs mark Link to comment Share on other sites More sharing options...
Opie Posted February 10, 2008 Share Posted February 10, 2008 On the '05's and early '06's the sensor activates with as little as 5 lbs on it. The middle of '06 and on use a different type of sensor that activates between 80-100lbs. Sounds like it's working fine. Link to comment Share on other sites More sharing options...
Bimmer Posted February 11, 2008 Share Posted February 11, 2008 You can probably "adjust" the sensor so that the passenger airbag is always on... Ben Link to comment Share on other sites More sharing options...
ehsnils Posted February 11, 2008 Share Posted February 11, 2008 Just tell your wife to buckle up. In that case the need for the airbag is decreasing. OK - you may still want it to work - since it's there for a reason. Link to comment Share on other sites More sharing options...
Voytech Posted February 11, 2008 Share Posted February 11, 2008 The simplest solution would be to let her drive Link to comment Share on other sites More sharing options...
longislander1 Posted February 12, 2008 Author Share Posted February 12, 2008 The simplest solution would be to let her drive Then I might need more than the belt and the airbag. She got her own Outback last August. Thanks to all for the advice. I'm taking the car in on Friday. Link to comment Share on other sites More sharing options...
