Guest Posted February 5, 2008 Share Posted February 5, 2008 Well the dealership wants 1300$ for a OEM cluck,no flywheel,no TOB.And I kinda want too go stg2 anyways because I will eventually do a turbo upgrade.So why not now then later. Don't ever deal with that stealer for anything, even oil change, that's beyond greedy. And tell them that. Link to comment Share on other sites More sharing options...
hifonic Posted February 5, 2008 Author Share Posted February 5, 2008 ^Who are you talking about,the dealership? Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2008 Share Posted February 5, 2008 ^Who are you talking about,the dealership? Of course, the $1300 stearlership... their cost is probably like $200-220.... and they want $1300 Link to comment Share on other sites More sharing options...
hifonic Posted February 5, 2008 Author Share Posted February 5, 2008 Yeah tell me about it lol. Link to comment Share on other sites More sharing options...
Stewy612 Posted February 5, 2008 Share Posted February 5, 2008 uh ill admit to making my shifts really smooth and taking a long time gettin the clutch out sometimes but i don't roll around wit hit in Link to comment Share on other sites More sharing options...
hifonic Posted February 5, 2008 Author Share Posted February 5, 2008 Same here,I'll get on it every now and then,but I don't miss shifts or anything.Hopefully with this stg2 clutch though it will be a little more forgiving. Link to comment Share on other sites More sharing options...
f1anatic Posted February 5, 2008 Share Posted February 5, 2008 I have had clutch smoke shoot out of the hood scoop too.. Read my sig Same here. Link to comment Share on other sites More sharing options...
Stewy612 Posted February 5, 2008 Share Posted February 5, 2008 i do get really really really bad shuddering in traffic after a while though..like really bad...i've got the ACT Street setup Link to comment Share on other sites More sharing options...
hifonic Posted February 5, 2008 Author Share Posted February 5, 2008 ^Damn is that normal? Link to comment Share on other sites More sharing options...
Stewy612 Posted February 5, 2008 Share Posted February 5, 2008 dunno, kinda hoping to find out about it...only about 3k on the clutch too Link to comment Share on other sites More sharing options...
hifonic Posted February 5, 2008 Author Share Posted February 5, 2008 Damn,well good luck with that.Hopefully you don't end up like me lol. Link to comment Share on other sites More sharing options...
SBT Posted February 5, 2008 Share Posted February 5, 2008 By the way, if the TOB took a powder and bulloxed up the pressure plate (or the tranny case), which then caused the clutch disc to prematurely wear-out (or get soaked with tranny lube), and you're under 60K miles, then that should be covered under the powertrain warranty. Talk to the tech who did the inspection and ask him/her to tell you what caused what. Also, since you bought the car from a dealer, and if SOA won't step up to the plate, then you should be able to get them to fix this, or at least half costs with you. Getting the OEM Parts at discount might be helpful. Here's what I priced at 1stSubaruParts.com (a Subaru dealership in Portland that I buy in bulk from regularly for all the Subes), and with the standard discount (normally 20-30%) the parts price is ~$725.00 as listed below. You'll likely pay $35-$45 shipping on that (just don't accept the 10% tag for shipping - give them a call and they'll work it out with you.). I just bought $1300 worth of parts from them and my shipping was $58.00 for overnight (which they bent over backwards to accomodate IMHO). If nothing else, use the dealer prices listed below as a reference with your dealership. Anyway good luck and hope it all works out for you. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Stewy612 Posted February 5, 2008 Share Posted February 5, 2008 Damn,well good luck with that.Hopefully you don't end up like me lol. already did on the stock clutch Link to comment Share on other sites More sharing options...
hifonic Posted February 5, 2008 Author Share Posted February 5, 2008 Well here the deal,they have'nt done a tear down on the car and I don't want to pay them to get one.Because am done dealing with them,am just going to get the work done outside the dealership.Because they told me a clutch is not covered under warranty because a clutch is a wearable item,just like brake pads. Link to comment Share on other sites More sharing options...
SBT Posted February 5, 2008 Share Posted February 5, 2008 Well here the deal,they have'nt done a tear down on the car and I don't want to pay them to get one.Because am done dealing with them,am just going to get the work done outside the dealership.Because they told me a clutch is not covered under warranty because a clutch is a wearable item,just like brake pads. But only the clutch disk is a wear item. The TOB, the Pressure Plate and the Transmission (snout) are all covered under the 60K mile. And, if the TOB or PP failed, then you have a case for warranty coverage. Spend the time, since your car is stock and hasn't been modded, to make the case. Worse that can happen is that you buy a new disk and let them install it when they replace the other warrantied parts. Did the tech drive this, or just eyeball it. If it's driveable, and they haven't driven it, then they don't know whether they're correctly diagosing the situation. Either way, a tear-down is then covered under warrantee too. In the final analysis, it's your decision. But if it's the TOB or the PP, then press the issue, especially since there's "smoke" associated with it. That clearly sounds like Powertrain Warranty to me. Incidently, which dealership did you buy it from and is it the same dealership that's giving you the Heisman? SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Stewy612 Posted February 5, 2008 Share Posted February 5, 2008 thats not what they said to me...had to pay for everything cause the clutch caused it Link to comment Share on other sites More sharing options...
CTATV Posted February 5, 2008 Share Posted February 5, 2008 thats not what they said to me...had to pay for everything cause the clutch caused it why they are often called stealerships Link to comment Share on other sites More sharing options...
hifonic Posted February 5, 2008 Author Share Posted February 5, 2008 Yea well the car is not drivable,it won't go into gear.But you know I would love to take the time and have the dealership do it,then stick it in there face afterwards.But I need the car now, and the dealership just gonna take their sweet time with it.So I think am gonna pass on going with the dealership. Link to comment Share on other sites More sharing options...
SuperCleanLGT Posted February 5, 2008 Share Posted February 5, 2008 i do get really really really bad shuddering in traffic after a while though..like really bad...i've got the ACT Street setup If this is a 6-puck clutch set up or a normal round clutch w/aggresive friction they have a tenndancy to "shudder". They have a stronger grip for more power but less streetability. Unless i'm racing or build a high powered engine I keep the factory clutch set up. Link to comment Share on other sites More sharing options...
qikslvr Posted February 5, 2008 Share Posted February 5, 2008 thats not what they said to me...had to pay for everything cause the clutch caused it +1 If a part that is not covered by the warranty causes damage to a part that is under warranty; none of the broken parts are covered by the warranty. They can do this by saying that failure to maintain/replace the "normal wear item" is what damaged the other parts so it's your fault not theirs. Let's kick this pig! Link to comment Share on other sites More sharing options...
hifonic Posted February 5, 2008 Author Share Posted February 5, 2008 Well thanks for all your support and advice guys.Am pretty much decided on what am going too do now. Link to comment Share on other sites More sharing options...
SBT Posted February 5, 2008 Share Posted February 5, 2008 Good luck with whatever route your go. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
