Sniperdan Posted January 21, 2008 Share Posted January 21, 2008 I've been searching around but can't find the answer. can i get the calipers and rotors off an STi and put them on my 07 spec b? wounld this be an upgrade? Link to comment Share on other sites More sharing options...
fweasel Posted January 21, 2008 Share Posted January 21, 2008 Yes you can and yes they will. The front calipers will bolt right on. Only 04 STi front rotors will work for your 5x100 hubs. The rear calipers require adapter brackets as well as a hybrid rotor. You cannot use the STi rear rotors because of the parking brake differences. You can get both the brackets and rotors together from Mach V As far as the upgrade goes... your stopping distance won't be affected much, but you'll gain better pedal feel and more fade resistance due to the additional mass of the calipers. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
whitetiger Posted January 21, 2008 Share Posted January 21, 2008 yeah, but you wont notice the fade resistance or feel that much. he's better off just buying better pads and SS brakelines with better fluid. Link to comment Share on other sites More sharing options...
Sniperdan Posted January 21, 2008 Author Share Posted January 21, 2008 i thought it would be an upgrade because they are bigger and i thought they came slotted or something. but hey Brembo calipers are a good thing to have! Link to comment Share on other sites More sharing options...
fweasel Posted January 21, 2008 Share Posted January 21, 2008 it won't hurt anything. As far as size, yes, they are bigger, but not by much. That's not where their advantage comes in to play when used on the Legacy. As Whitetiger mentioned, the benefits will not be realized on the street, at least not enough to justify the cost vs a basic pad and fluid upgrade. Many people, including myself, have done just fine at the track with OEM calipers, stock sized rotors, upgraded pads, and upgraded fluid. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
Sniperdan Posted January 21, 2008 Author Share Posted January 21, 2008 ok thanks for the info, hawk pads and fluid it is! Link to comment Share on other sites More sharing options...
fweasel Posted January 22, 2008 Share Posted January 22, 2008 Good man. Now take some of that money you've just saved and paypal a percentage to whitetiger and I:lol: ignore him, he'll go away. Link to comment Share on other sites More sharing options...
dan_m Posted January 22, 2008 Share Posted January 22, 2008 I agree that LGT brakes are quite sufficient so long as you have decent pads Link to comment Share on other sites More sharing options...
AKLGT Posted January 22, 2008 Share Posted January 22, 2008 I have brembo BBK on my LGT. it was necessary once I upgraded the turbo. however, with the stock VF40/43, upgraded pads and fluid will do the job nicely. remember, stock LGT brakes are the same as the Tribeca, they are also about 50% larger than the stock WRX. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
whitetiger Posted January 22, 2008 Share Posted January 22, 2008 Good man. Now take some of that money you've just saved and paypal a percentage to whitetiger and I:lol: If only... Link to comment Share on other sites More sharing options...
Sniperdan Posted January 22, 2008 Author Share Posted January 22, 2008 Oh i didn't save anything, i just have a new way to put it to "the boss" so it sounds like i'm saving and i can get some new toys! Link to comment Share on other sites More sharing options...
dan_m Posted January 22, 2008 Share Posted January 22, 2008 ^ my advice to you is don't search the forums for pictures of brembos mounted on LGTs... just...............don't Link to comment Share on other sites More sharing options...
KNS Brakes Posted January 23, 2008 Share Posted January 23, 2008 ^ my advice to you is don't search the forums for pictures of brembos mounted on LGTs... just...............don't don't ask me if I have 2 sets of Brembo's laying around either......with all the brackets and fr/rr rotors and rear bracket adaptor needed to bolt right up...... Link to comment Share on other sites More sharing options...
Sniperdan Posted January 23, 2008 Author Share Posted January 23, 2008 right then don't tell me your with in driving distance to save on shipping either..... Link to comment Share on other sites More sharing options...
AKLGT Posted January 23, 2008 Share Posted January 23, 2008 BURU has a set for F/R brembos in the FS threads. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
Guest Posted January 25, 2008 Share Posted January 25, 2008 I was in teh "BBK is bling only" camp, but I succumbed. STI Limited Brembos for all 4 corners waiting for install Link to comment Share on other sites More sharing options...
edekba Posted January 25, 2008 Share Posted January 25, 2008 Sti Limited = Black ? Those are sweeeet. I have them. Link to comment Share on other sites More sharing options...
