johnAWD Posted January 4, 2008 Share Posted January 4, 2008 You and me both, Sspeed. Ha ha, maybe I'm being a cheap ex-DSM'er... Link to comment Share on other sites More sharing options...
el scorcho Posted January 4, 2008 Share Posted January 4, 2008 blown hoses would result in a serious loss of power, right? Link to comment Share on other sites More sharing options...
HansGT Posted January 4, 2008 Share Posted January 4, 2008 ^ yeah, you will not hit full boost. Link to comment Share on other sites More sharing options...
qikslvr Posted January 4, 2008 Share Posted January 4, 2008 Just make sure to use all new OE gaskets for the manifold->UP, UP->Turbo, Turbo-DP and DP->MP. This should make for fewer if any leaks and no gasket blowouts later on. Let's kick this pig! Link to comment Share on other sites More sharing options...
hutru01 Posted January 4, 2008 Share Posted January 4, 2008 ^ +1000000 on new gaskets Link to comment Share on other sites More sharing options...
HansGT Posted January 4, 2008 Share Posted January 4, 2008 ^ + new up pipe studs....which come with the Invidia. And you'll need a bolt to plug up the probe hole in the UP. I have the size at home...I can check. Actually I had mine welded closed. Link to comment Share on other sites More sharing options...
BDII Posted January 4, 2008 Share Posted January 4, 2008 Just weld the edges of the STi Up. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
