BDII Posted January 2, 2008 Share Posted January 2, 2008 Yeah.... anyone got one? or can anyone tell me what the wires are? I searched for the PDF but found nothing... Red = power Black = ground Orange = ? White= ? Green = ? Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
LGT Dave Posted January 2, 2008 Share Posted January 2, 2008 From their FAQ page (http://prosportgauges.com/faqs.aspx): Q: I lost my instructions how do I wire the performance Series gauge? A: Black –Ground Red - 12v ign. power-meaning power when the ignition is on. White- 12v ign. power Orange-Headlight switch. Green - Sender The above/below wiring will result in white during the day and color (amber or Green) at night. Looks like it hooks up the same as my boost gauge did. The white and orange wires control the lighting of the gauge (white for white light, orange for amber). Whichever one you hook up to the 12v power (same wire you connect the red wire to) will be what color the gauge is with the headlights off. If you want the gauge a different color when the headlights are turned on, then you can connect the other wire to one of the Accessory Illumination wires behind the dash (pretty much any purple wire back there). The green wire on my boost gauge connects to the white wire on the boost sensor. Not sure if that's the same for the AFR sensor or not. Link to comment Share on other sites More sharing options...
ddavis Posted January 2, 2008 Share Posted January 2, 2008 If you run power to the white or orange wires it will change the color of the gauge. The gauge is red by default with those 2 disconnected Link to comment Share on other sites More sharing options...
BDII Posted January 3, 2008 Author Share Posted January 3, 2008 which ones make the gauge match the stock gauges? Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
LGT Dave Posted January 3, 2008 Share Posted January 3, 2008 The white wire connected to the 12v power will make the gauge white. It's close to the white gauges in the instrument cluster, but my boost gauge is not a perfect match. My prosport gauge has a little bit more blue in it than the stock gauges do. Link to comment Share on other sites More sharing options...
ddavis Posted January 3, 2008 Share Posted January 3, 2008 I left the orange and white wire disconnected, because I thought the default red gauge matched the stock gauges with the headlights on better. The white was a bit to bright for my liking. I just tested the gauge on a power source first to see what colors I liked most before installing mine. Also the orange wire gave me a orange gauge Link to comment Share on other sites More sharing options...
BDII Posted January 3, 2008 Author Share Posted January 3, 2008 what did you splice the green wire into? Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
ddavis Posted January 3, 2008 Share Posted January 3, 2008 I didnt end up installing it. I was told the blue wire on the rear 02 will pull the signal and I should tap it there. Might want to drop prosport a email also for suggestions. Also the gauge will only read accurate at WOT, so from normal driving conditions you will see it moving lean to rich so you know. Link to comment Share on other sites More sharing options...
BDII Posted January 3, 2008 Author Share Posted January 3, 2008 Someone recommended to the UP 02 sensor.... But I have the STi Up so that's a a no go. Thanks for the heads up!!! I'll run it off the DP 02 sensor Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
dwolson2 Posted May 28, 2011 Share Posted May 28, 2011 I didnt end up installing it. I was told the blue wire on the rear 02 will pull the signal and I should tap it there. Might want to drop prosport a email also for suggestions. Also the gauge will only read accurate at WOT, so from normal driving conditions you will see it moving lean to rich so you know. is there anyway around this? Link to comment Share on other sites More sharing options...
