davester_exallroad Posted December 22, 2004 Share Posted December 22, 2004 What tire psi would you guys recommend for the best gas mileage ?? For a LGT wagon? Front ? Rear ?Thanks.. Link to comment Share on other sites More sharing options...
Drift Monkey Posted December 22, 2004 Share Posted December 22, 2004 Higher than stock. I personally run 39F/37R on my sedan. Link to comment Share on other sites More sharing options...
sduford Posted December 22, 2004 Share Posted December 22, 2004 I would say start with 3-4 PSI above the recommended and see how that works out for you. Most people do not go above that as it negatively impacts the ride and may cause tire wear problems. Sylvain www.digitalfotographer.com - Audi Q5 Club - MB-GLK Club Link to comment Share on other sites More sharing options...
Drift Monkey Posted December 22, 2004 Share Posted December 22, 2004 I have to say though, I didn't do it for better mpg... Link to comment Share on other sites More sharing options...
gtguy Posted December 22, 2004 Share Posted December 22, 2004 The only time that an increased pressure will cause tire wear difficulties is if you go so high that it causes the tire to bow outward. But the ride quality deterioration would be noticeable far before things got that far along. Kevin Link to comment Share on other sites More sharing options...
Ken S Posted December 22, 2004 Share Posted December 22, 2004 Well, I was running stock pressures and I was begining to get inside-outside wear on the tires. My tuning shop recommended to up the pressure by 5psi all around to 40 front/38 rear on my LGT wagon. They noted the RE92s don't have very stiff sidewalls. The increased pressure has improved handling quite a bit with only a slightly firmer ride. I can't say that gas milage has changed though. Ken Link to comment Share on other sites More sharing options...
