whitetiger Posted December 12, 2007 Share Posted December 12, 2007 So After 48K miles and 3yrs of ownership, I get my first real interior rattle. Somthing in my rear view mirror is making a noise at a certian engine RPM. The mirror still works great, but somthing is loosening up inside the unit. If i hold the mirror, it stops, so its definitly the mirror. It not too anoying yet, but im sure it will get worse over time. Anyone have a similar problem? I should consider myself lucky since i shoould have more rattles with the stiff suspension i have. Link to comment Share on other sites More sharing options...
iyalla Posted December 12, 2007 Share Posted December 12, 2007 Have you tried tightening the nut that holds the mirror mount to the glass mount. It gets loose sometimes and the mirror starts to vibrate. You can tell because the reflection gets shaky when you are driving. Link to comment Share on other sites More sharing options...
Opie Posted December 12, 2007 Share Posted December 12, 2007 It's a Torx T-20! Link to comment Share on other sites More sharing options...
whitetiger Posted December 12, 2007 Author Share Posted December 12, 2007 Its not the bolt. Its in the mirror itself. It sound like its right behind the glass. Link to comment Share on other sites More sharing options...
rs6er Posted December 12, 2007 Share Posted December 12, 2007 Try replacing the spring clip. Link to comment Share on other sites More sharing options...
LongHiway Posted December 13, 2007 Share Posted December 13, 2007 On my mirror, there is a plastic sleeve that covers the wires from the headliner down to the mirror. It sort of looks like a trim piece for the mirror mount itself. Every once in a while, this sleeve slips down and rattles against the window at various times, roads, speeds and so on. As far as I know, it is supposed to be loose so, I just pushed it back upwards a little and, my rattle was solved. Link to comment Share on other sites More sharing options...
whitetiger Posted December 13, 2007 Author Share Posted December 13, 2007 again, it if were simple like a loose trim piece or bolt or clip, i would have fixed it. the rattle is inside the unit itself. If i flick the mirror with my finger, i can hear the rattle. Link to comment Share on other sites More sharing options...
fweasel Posted December 13, 2007 Share Posted December 13, 2007 again, it if were simple like a loose trim piece or bolt or clip, i would have fixed it. the rattle is inside the unit itself. If i flick the mirror with my finger, i can hear the rattle. What do you need us for then, sounds like you've got it pinned down. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
whitetiger Posted December 13, 2007 Author Share Posted December 13, 2007 Im not trying to find a solution. Im reporting the proble to see if other people have seen the same issue. Im essentially documenting the problem for public reccord as a service to the community. Isnt that the purpose of this sub-forum? Link to comment Share on other sites More sharing options...
fweasel Posted December 13, 2007 Share Posted December 13, 2007 not sure what the exact purpose is. Well, your rattle is documented, along with the other people who have had the same issue. I inferred that you were seeking a soultion from your initial post, but seems you just want people to know about it. My bad. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
