Xenonk Posted December 21, 2004 Share Posted December 21, 2004 [url]http://forums.nasioc.com/forums/showthread.php?t=685663[/url] Check it.. PM EndlessShine for details. Keefe Keefe Link to comment Share on other sites More sharing options...
John M Posted December 21, 2004 Share Posted December 21, 2004 You do know you can splice radio antennas with regular wire, right? I did that installing an FM modulator setup in a Lexus LS430 and everything worked great. It's quite easy to add an item with standard Motorola radio plugs to a non-standard system without losing the AM/FM reception. Link to comment Share on other sites More sharing options...
Th3Franz Posted December 21, 2004 Share Posted December 21, 2004 [quote name='John M']You do know you can splice radio antennas with regular wire, right? I did that installing an FM modulator setup in a Lexus LS430 and everything worked great. It's quite easy to add an item with standard Motorola radio plugs to a non-standard system without losing the AM/FM reception.[/QUOTE] Isn't it usually a good idea to try to maintain the shielding though? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
John M Posted December 21, 2004 Share Posted December 21, 2004 Theoretically, yes. However, in my case it worked fine without it. No noise present in AM (damn talk radio) or FM, or in the new unit's sound quality (Kenwood music keg). You could also use all shielded cable by buying an antenna extension for a few bucks. That'd give you 10 feet of cable to work with and a male & female motorola end to splice into your setup. Link to comment Share on other sites More sharing options...
