The Don Posted December 8, 2007 Share Posted December 8, 2007 both lights do not go on. i hear the ballests whineing like they do when there on? Could i have blown a fuse? Link to comment Share on other sites More sharing options...
VXCL Posted December 8, 2007 Share Posted December 8, 2007 both lights do not go on. i hear the ballests whineing like they do when there on? Could i have blown a fuse? if both are whining that is normal, but for both not to stop working at the same time is very strange... i would test them by hooking to batt manually. possible you blew the ignitors, bulbs or maybe something crazy with your drl. if you hooked them up to the factory wiring then it could be several things. one of the many reasons i am completely against that and build my own wire harnesses. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
abakja1 Posted December 8, 2007 Share Posted December 8, 2007 If you have relays on your wiring harness, you can open it up and see if they are corroded,..I found mine to be like this,.. Kevin Link to comment Share on other sites More sharing options...
The Don Posted December 8, 2007 Author Share Posted December 8, 2007 my old kid got corroded got new one they still were messed up got a new kit and they were fine..i think the wiring harnesses that are made now a days are just garbage but thats beside the point. Link to comment Share on other sites More sharing options...
HangKen Posted December 8, 2007 Share Posted December 8, 2007 Could it be the weather. I don't know too much about it but my HID's on my civics were like that for some reason. The one that I have right now has a problem with just the right one. Some times it goes on and some times, I need to turn off the lights, and turn on the lights. Either way, maybe you might be able to send it over to the manufacture for some warranty? Link to comment Share on other sites More sharing options...
VXCL Posted December 10, 2007 Share Posted December 10, 2007 until you start testing components individually to isolate the problem, its just a guessing game. again the fact that both went out at the same time means 1. something very stupid or 2. something very bad MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
