PhilT Posted December 4, 2007 Share Posted December 4, 2007 Buying out the lease on my car, I had to go get an emisions and safety checks done as per Ontario law. I wasn't sure what the outcome would be, and I'm damn glad I kept the stock DP with those nice friendly cats in them. Results were: HC ppm ~ Limit 150, reading 1 CO% ~ Limit 0.70, reading 0.01 The tree huggers will be proud Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
gianspi Posted December 4, 2007 Share Posted December 4, 2007 Congrats enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
gianspi Posted December 4, 2007 Share Posted December 4, 2007 What does HC stand for BTW? enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
NateWA Posted December 4, 2007 Share Posted December 4, 2007 hydrocarbons? Link to comment Share on other sites More sharing options...
PhilT Posted December 4, 2007 Author Share Posted December 4, 2007 hydrocarbons? Correct I can't believe how enviromentally friendly this car is Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
GTCanada Posted December 4, 2007 Share Posted December 4, 2007 Do you still have the catted UP on the car? Link to comment Share on other sites More sharing options...
PhilT Posted December 4, 2007 Author Share Posted December 4, 2007 Do you still have the catted UP on the car? No, catless UP and the stock DP. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
LittleBlueGT Posted December 4, 2007 Share Posted December 4, 2007 HC ppm ~ Limit 150, reading 1 CO% ~ Limit 0.70, reading 0.01 I wonder what it would have been with a HFC. Those results make me think a HFC might have passed. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
bugblatterbeast Posted December 4, 2007 Share Posted December 4, 2007 how did you use the stock DP with the AVO420? Did blocking the WG cause boost problems or did you drive the car to the emissions place super gently? Link to comment Share on other sites More sharing options...
Jim_KT Posted December 5, 2007 Share Posted December 5, 2007 how did you use the stock DP with the AVO420? Did blocking the WG cause boost problems or did you drive the car to the emissions place super gently? Inquiring minds want to know. Link to comment Share on other sites More sharing options...
Infamous1 Posted December 5, 2007 Share Posted December 5, 2007 The AVO420 would act no differently then your stock VF40. Almost certain he wouldn't be boosting it like crazy knowing the stock cat is there. I had to do the same when the CHP sent me to see the referee. I just changed to the stock DP and thats it passed with flying colors. Link to comment Share on other sites More sharing options...
tytek Posted December 5, 2007 Share Posted December 5, 2007 PhilT, is the car still for sale? Or have you decided to keep it? Link to comment Share on other sites More sharing options...
PhilT Posted December 5, 2007 Author Share Posted December 5, 2007 how did you use the stock DP with the AVO420? Did blocking the WG cause boost problems or did you drive the car to the emissions place super gently? Just kept it out of boost all the way to the test centre, then straight into the test, no waiting around. PhilT, is the car still for sale? Or have you decided to keep it? The car is up for sale still, but if it doesn't sell for a while I won't be too upset Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
bugblatterbeast Posted December 5, 2007 Share Posted December 5, 2007 The AVO420 would act no differently then your stock VF40. Almost certain he wouldn't be boosting it like crazy knowing the stock cat is there. I had to do the same when the CHP sent me to see the referee. I just changed to the stock DP and thats it passed with flying colors. What about the flow separator which is flush with the mating surface. A flat flange DP will block all the wastegate flow. Link to comment Share on other sites More sharing options...
PhilT Posted December 5, 2007 Author Share Posted December 5, 2007 What about the flow separator which is flush with the mating surface. A flat flange DP will block all the wastegate flow. Yes it does, with the stock DP you basically have no wastegate, therefore it has to be driven extremely gently. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Infamous1 Posted December 5, 2007 Share Posted December 5, 2007 What about the flow separator which is flush with the mating surface. A flat flange DP will block all the wastegate flow. Uh durr, forgot about that still not an issue to a short trip to the smog shop and a 2500rpm fast idle test. Link to comment Share on other sites More sharing options...
Elec Posted December 5, 2007 Share Posted December 5, 2007 I just passed a (4 minute) emissions test in MD last weekend. It was sorta ridiculous how little they checked. The guy tried to do a gas cap pressure test but didn't have the right adapter. So all they ended up doing was pulling OBD codes. No visual inspection, no treadmill test, no tailpipe sniffer. Made me wish I wasn't stock Link to comment Share on other sites More sharing options...
bugblatterbeast Posted December 7, 2007 Share Posted December 7, 2007 Buying out the lease on my car, I had to go get an emisions and safety checks done as per Ontario law. I wasn't sure what the outcome would be, and I'm damn glad I kept the stock DP with those nice friendly cats in them. Results were: HC ppm ~ Limit 150, reading 1 CO% ~ Limit 0.70, reading 0.01 The tree huggers will be proud good to see that Ontario hasn't put in a NOx test for 4wd cars yet. too bad our EM doesn't allow mixtures targets leaner than 14.7. I bet we could pass with no cat if we could dial in lean mixtures Link to comment Share on other sites More sharing options...
Deer Killer Posted December 7, 2007 Share Posted December 7, 2007 it probably does, but no one has found the CL mixture yet. Link to comment Share on other sites More sharing options...
