RobY Posted December 1, 2007 Share Posted December 1, 2007 Heres the story. After dealing with the suckage of the stock cluch for a while I replaced the cluch once with the RPS 2.5 RS combo. The 2.5 RS combo has been working well since but is starting to show signs that it needs to be replaced. I ordered the ACT HDMM kit from Harman Motive a few weeks ago. The kit comes with: The Pressure Plate The Friction Disc The Flywheel A Pilot Bearing A Throw out Bearing An alignment tool. Rumor has it that the TOB that comes with the kit is not the greatest... Would an OEM WRX TOB work? If some of you could help me out I need to know the part numbers and how many of the following I need. Im replacing all the fasteners and the TOB fork because the clutch has been replaced once already and I like to start fresh. I need to know how many and the part numbers to: Flywheel to Motor Bolts... Pressure Plate to Flywheel Bolts... Do I order ones for the WRX or the LGT? I need the part numbers to: The WRX/LGT TOB Fork? Are they the same? Anything else I might need? Thanks for all your help. Link to comment Share on other sites More sharing options...
BLKGT5 Posted December 3, 2007 Share Posted December 3, 2007 "Rumor has it that the TOB that comes with the kit is not the greatest" That's correct mine sucks, it makes noise some day's and not on other days. Link to comment Share on other sites More sharing options...
Beanboy Posted February 17, 2008 Share Posted February 17, 2008 Just got the clutch kit installed. As far as throwout bearing is concerned, rattle off throttle between 1800 to 2500RPM or so? Goes away when you hit the clutch pedal? -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
tytek Posted February 17, 2008 Share Posted February 17, 2008 Here is my tip: Don't do it! Link to comment Share on other sites More sharing options...
