BLKGT5 Posted November 30, 2007 Share Posted November 30, 2007 I've heard that a WRX 06+ Dual Mass Flywheel works on a 2005 Legacy GT. Is this correct? I'm using a ACT Lightweight Flywheel with a HD Pressure plate and street disc. Will the WRX 06+ Dual Mass Flywheel work with this setup? How much does a WRX 06+ Dual Mass Flywheel usally cost? The stupid throw out bearing has already failed (1500miles) with this new ACT setup and the 1500 rpm or below shudder really sucks! It even rattles when decelerating using the engine to slow the vechical down, which I usally dont do. Crappy setup which I don't recommend unless it's a purely drag strip car. Link to comment Share on other sites More sharing options...
ABPillinois Posted November 30, 2007 Share Posted November 30, 2007 The 06+ WRX does not have a dual mass fly it is single mass weighs about 23.8 lbs. It will work with your ACT Clutch, the LW ACT fly is the same design as the OEM WRX unit. $199 from King of parts FYI. :rolleyes:"All right, brain, I don't like you and you don't like me - so let's just do this and I'll get back to killing you with beer." Link to comment Share on other sites More sharing options...
BLKGT5 Posted November 30, 2007 Author Share Posted November 30, 2007 Hmm if that's the case, I guess only the Legacy runs the dual mass flywheel? Is it the ACT heavy duty pressure plate or the street disc that's causing the shuddering? I'm wanting better grip than a stock clutch but without the shudder and the non exsistant dampering of the throw out bearing. How does Subaru keep this from occuring on the 06+ WRX? Can I run my clutch and pressure plate with a dual mass Legacy flywheel and would that remove the shudder? Thanks! Link to comment Share on other sites More sharing options...
ABPillinois Posted November 30, 2007 Share Posted November 30, 2007 There is a 10# difference between the Act fly and Wrx you are getting what they call chatter from the Act fly being to light. Act does not currently make a clutch that will work with the Legacy dual mass FW, only Spec clutches have an upgraded clutch for use with our flywheel. FAIK there are a few members with the Act street clutch and the OEM Wrx fly with good results (very little chatter and alot better drivability). There are a couple threads here with great info on different setups. :rolleyes:"All right, brain, I don't like you and you don't like me - so let's just do this and I'll get back to killing you with beer." Link to comment Share on other sites More sharing options...
BLKGT5 Posted November 30, 2007 Author Share Posted November 30, 2007 Thanks for the information! You have been very Helpful! Link to comment Share on other sites More sharing options...
ABPillinois Posted December 1, 2007 Share Posted December 1, 2007 NP been doing alot of research I think the ACT clutch and Wrx fly will be my setup after first of year. :rolleyes:"All right, brain, I don't like you and you don't like me - so let's just do this and I'll get back to killing you with beer." Link to comment Share on other sites More sharing options...
Mr. Ed Posted December 1, 2007 Share Posted December 1, 2007 Yeah Act+ Wrx fly seems to be the best bang for the buck.... I went a cheaper route but will end up with act if this one doesn't hold up Link to comment Share on other sites More sharing options...
Infamous1 Posted December 1, 2007 Share Posted December 1, 2007 I haven't heard too many complaint with the LWFW wit the full face disc setup. Maybe your FW was possibly installed without the ring? Link to comment Share on other sites More sharing options...
BLKGT5 Posted December 3, 2007 Author Share Posted December 3, 2007 I had told the installer that the ring had to be left on, so I hope they did. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted December 3, 2007 Share Posted December 3, 2007 It is nice to finally see a few here understand how this works, and can help others. It definitely took long enough! Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
ABPillinois Posted December 4, 2007 Share Posted December 4, 2007 Word! :rolleyes:"All right, brain, I don't like you and you don't like me - so let's just do this and I'll get back to killing you with beer." Link to comment Share on other sites More sharing options...
