Beanboy Posted November 26, 2007 Share Posted November 26, 2007 Currently have a shorty DP, everything else stock exhaust-wise. 20G turbo is in the works. It appears I'll be losing 15-20AWHP depending on what aftermarket option is chosen versus what I have now. I first thought replacing the shorty DP and going for a full 3" catted exhaust back to aftermarket y-pipes and cans would be worth it and reasonably cost-effective. Then I started reading about having to hack off tapered 2.5" sections/donut flanges of some of the more popular 3" downpipes to have them work with 3" flanged midpipes and for the full 3" downpipes, some folks having fitment or harmless CELs being thrown at highway speed. And then there's the issue with most sedan mufflers being too short for the wagon, as well as droning on the highway thanks to the wagon body style. So wagon owners with aftermarket turbos, how are you handling your catted exhaust issues that keeps the wife happy? Stock mufflers with aftermarket everything else seems to be a popular option... -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
nekdut Posted November 26, 2007 Share Posted November 26, 2007 AVO downpipe, Perrin Y/center pipes, AVO Mufflers for the BP5. Fits fine and is 3 inches all of the way through to 2-2.5" pipes/cans. Link to comment Share on other sites More sharing options...
Beanboy Posted November 26, 2007 Author Share Posted November 26, 2007 Thanks nekdut. Around $1700 correct? Jeeze, might as well go bigger turbo and have it blow-out the OEM muffler baffles. . -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
praedet Posted November 26, 2007 Share Posted November 26, 2007 Right now I am running the Crucial shorty DP and catted mid-pipe. I will be adding the COBB Y-pipe w/ a resonator welded in, going to lobotomized stock cans w/ custom tips. At some point down the line I will switch to a full 3inch DP, but it is not a bid deal yet... Link to comment Share on other sites More sharing options...
tytek Posted November 26, 2007 Share Posted November 26, 2007 I am battling the same issue. Other than a header crosspipe, flow shorty, and lack of resonator, my exhaust is stock. It seems that the stock cat affects the flow, but so does the Y-pipe and the stock cans. I am going with an FP Green setup and will need to get the exhaust figured out soon. I planed on drilling through the stock muffler baffles to improve flow, a high flow cat/mid pipe, and a custom y-pipe made by a local shop. But if a simpler and/or more cost effective way exists, I am all ears to it. Link to comment Share on other sites More sharing options...
Beanboy Posted November 26, 2007 Author Share Posted November 26, 2007 Ah, guess I'm not the only one! MR single tip CBE with 2" silencer seems like it might work out in terms of both being decently quiet and fitting the wagons, really looking forward to seeing them hit the streets early January. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
