andrew.anderson Posted May 31, 2008 Author Share Posted May 31, 2008 $349.99 Everex 7" CloudBook CE1200V Ultra-Portable Laptop w/ VIA C7-M Processor ULV http://i.walmartimages.com/i/p/00/85/30/31/00/0085303100191_500X500.jpg Specifications: Processor Brand: VIA Processor Type: C7-M Hard Drive Size: 30GB System RAM: 512 MB Display Display Type: 7" TFT Widescreen Display: Yes Max Resolution: 800 x 480 ( WVGA ) Processor Processor: VIA C7-M 1.2 GHz Chipset Type: VIA VX700 Data Bus Speed: 400 MHz Power Efficiency: Ultra Low Voltage (ULV) Cache Memory Type: L2 cache Installed Size: 128 KB Storage Hard Drive: 30 GB - 4200 rpm RAM Installed Size: 512 MB / 1 GB (max) Technology: DDR II SDRAM - 533 MHz Configuration Features: 1 x 512 MB Networking Data Link Protocol: Ethernet, IEEE 802.11b, IEEE 802.11g Wireless LAN Supported: Yes Video Video Memory: Shared video memory (UMA) Graphics Processor / Vendor: VIA UniChrome Pro Audio Audio Input: Microphone Operating System / Software OS Provided: GOS v2 Software: OpenOffice.org 2.3 Battery Technology: 4-cell lithium ion Installed Qty: 1 Capacity: 2200 mAh Product Dimensions Width: 9.1 in Height: 1.1 in Depth: 6.7 in Weight: 2 lbs \Miscellaneous Features: Security lock slot (cable lock sold separately), system password, hard drive password Power Voltage Required: AC 120/230 V ( 50/60 Hz ) Manufacturer Warranty Service & Support: 1 year warranty More Information Model No.: CE1200V Shipping Weight (in pounds): 4.0 Product in Inches (L x W x H): 13.3 x 9.1 x 3.5 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Wal-Mart No.: 000599723 Link to comment Share on other sites More sharing options...
andrew.anderson Posted May 31, 2008 Author Share Posted May 31, 2008 $154.95 7" TFT LCD Color Monitor Car Headrest 2-Pack w/Remotes (Blk) http://www.geeks.com/imageshare/V/300x300/VT-H702A-2PK-unit.jpg Enjoy movies in your car with the ViewTech VT-H702A 7-inch LCD Monitor Headrest Two-Pack! These 7-inch LCD monitors install easily into your car's seats by replacing your existing headrests with a pair that have LCDs pre-installed! The 7-inch LCD screens support standard and widescreen aspect ratios, for gaming or watching movies! Installation is easy, the monitors are designed to work with any 12V DC current and accept video input through a composite video connector. They also each feature a convenient slim remote control, an in-depth OSD menu, and brightness controls! Tailgate in style! Order this monitor two-pack now! Features/Specifications: * 7-inch TFT LCD Monitor Car Headrest w/Remote Two-Pack (Black) * General Features: * Black artificial leather headrests with black LCD frame * 7-inch TFT LCD screens * 163 x 123 mm (W x H) active area * High Resolution Panel : 1440 x 234 pixels (W x H) * 4:3 (standard) or 16:9 (widescreen) aspect ratios * Brightness: 300 cd/m² * Contrast ratio: 350:1 * Automatic switching between PAL/NTSC * Viewing angle: 120° horizontally, 100° vertically * Input terminal: AV (composite) * Control mode: manual or remote control * Response time: 10 ms * Adjustable headrest: forward and backward adjustment 35° * Adjustable tube diameter of headrest: 10, 12, 14 mm * Adjustable tube distance of headrest: stepless adjustment within 135 - 185 mm * Applicable to all car seats with headrest tube diameters of 10, 12, 14 mm and tube distance within 130 - 190 mm * Power Specifications: * Power consumption: 6W (each) * Power supply: 12V DC Package Includes: * Two (2) 7-inch TFT LCD Monitor Car Headrest * Two (2) Remote controls * Instruction guides Additional Information: * Notes: * Model: VT-H702A * Professional installation recommended * Product Requirements: * Compatible seats * Composite video source * 12V DC power source Link to comment Share on other sites More sharing options...
andrew.anderson Posted May 31, 2008 Author Share Posted May 31, 2008 $37.99 Sandisk Sansa e250 2GB MP3 Player, FM tuner, FM on-the-fly Recording, Built-in microphone, Video, Expandable Memory http://ak.buy.com/db_assets/prod_lrg_images/657/205562657.jpghttp://ak.buy.com/db_assets/screen_shot_images/657/205562657_005.jpg Features Included: USB Cable, White Earbuds Sleek, thin design with large 1.8” TFT color screen for easy viewing Strong alloy metal casing provides excellent durability and scratch resistance Simple to use, backlit controls for fast device interface navigation User replaceable and rechargeable Lithium Ion battery for up to 20 hours of battery life (Based on continuous playback at 128 kbps MP3; rechargeable batteries may eventually need to be replaced as they have limited charge cycles (which vary with use and settings) Features microSD™ expansion slot for additional memory capacity Supports SanDisk TrustedFlash and Gruvi content cards Digital FM tuner*, on-the-fly FM recording*, and voice recording No FM-tuner (and no FM-recording) is available in Europe Supports Subscription Music Stores Tech Specs Included: USB Cable, White Earbuds Built-in memory 2GB Expandable memory Yes Memory media/type Flash Memory Note: MB = megabytes, GB = gigabytes; actual formatted capacity may vary. File formats supported WMA Yes WAV Yes Music/data transfer Data file storage Yes USB 2.0 interface Yes Docking station No General features Type Music, photos and videos Color Screen Yes Video capability Yes Voice recording Yes Digital tuner Yes Playlist editing Yes DC jack No Height 3.5 inches Width 1.7 inches Depth 0.6 inches Weight 0.2 WARRANTY: 90 DAYS Link to comment Share on other sites More sharing options...
andrew.anderson Posted May 31, 2008 Author Share Posted May 31, 2008 You can use this to output the DVD Video to the headrest you bought in the other deal. $154.50 In-Dash DVD /AM/FM/ MP3/MP4 Player w/3.5" Mechanized TFT LCD http://www.geeks.com/imageshare/M/300x300/MOSFET-60WX4-UPC-unit.jpg Features/Specifications: * Mosfet 60 w x 4 In-Dash DVD Player w/3.5-inch Motorized TFT LCD * General Features: * Electronic Anti-Shock * 60W x 4 MOSFET high power output * Compatible with DVD/VCD/CD/CD-R/CD-RW/MP3 * Mechanized control panel (detachable) * 3.5-inch TFT Color LCD screen * NTSC/PAL compatible * Screen Angle/Position Memory * Rear Monitor Video Output * Repeat/Program/Random/Intro Play * AM/FM/MPX Stereo Receiver * 30 preset stations * Auto Memory Store/Preset Scan * Preset EQ (Pop/Rock/Classic) * DVD/VCD/Changer Control interface * Parking detector interface * 2V Preamp Output (2 pairs RCA) * TV Tuner control * Card sized Full Function Remote Control * Control Panel: * 3.5-inch screen * Secure Digital card slot (SD)/MMC slot * USB port * Volume control knob * Picture Control: * Brightness * Contrast * Color * Tint * Reflection Size * Video features: * 4:3 Letter Box and 4:3 Pan Scan * 1.0Vp-p 75 ohms video output level * 500 Horizontal Resolution * Audio features: * 2Vrms (± 3dB) * 20 to 20 Khz frequency response * 85 dB signal-to-noise ratio * 80 dB separation * AM Tuner features: * 530-1710 Frequency range * 450 KHz IF range * 25 dB usable sensitivity * FM Tuner features: * 87.5 - 107.9 tuning range * 10.7 MHz IF Range * 15 dB usable sensitivity * 60 dB signal-to-noise ratio * 30 dB (1 KHz) stereo separation * 30 ~ 1500 Hz frequency response * Dimensions: * 6.5" x 7.25" x 2.8" (D x W x H) approximate Package Includes: * In-Dash DVD/AM/FM/MP3/MP4 Player * 3.5-inch TFT LCD screen * Plastic carrying case for 3.5-inch TFT LCD screen * Filer and Fuse box cable * Remote control * Mounting parts * USB cable Link to comment Share on other sites More sharing options...
whobaru Posted May 31, 2008 Share Posted May 31, 2008 Dude, $37.99 for that MP3 is a smokin' deal! Link to comment Share on other sites More sharing options...
andrew.anderson Posted May 31, 2008 Author Share Posted May 31, 2008 Dude, $37.99 for that MP3 is a smokin' deal! I paid $45, which was a great deal, three weeks ago. Link to comment Share on other sites More sharing options...
Guest heightsgtltd Posted May 31, 2008 Share Posted May 31, 2008 Yeah but why? Link to comment Share on other sites More sharing options...
andrew.anderson Posted May 31, 2008 Author Share Posted May 31, 2008 Yeah but why? Because three weeks ago it was $45, not $37. Link to comment Share on other sites More sharing options...
Guest heightsgtltd Posted May 31, 2008 Share Posted May 31, 2008 edit.. I just looked at it, not bad, Link to comment Share on other sites More sharing options...
andrew.anderson Posted June 7, 2008 Author Share Posted June 7, 2008 $93.72 Ozark Trail 3-Dome Connection Tent (Sleeps 9-10) http://i.walmartimages.com/i/p/00/72/70/01/12/0072700112140_AV_500X500.jpg Features & Specifications Featuring three free-standing tents that can be connected through tunnels, this 3-dome connection tent from Ozark Trail is great for families with kids — parents can sleep in the larger, middle one with siblings in the smaller, adjacent tents. Made of GoBeDry for all-weather protection with a welcome front door mat that helps keep dirt out. Includes an expandable carry bag. Sleeps 9-10. Brands You Trust: Ozark Trail Ozark Trail promises to provide you with the best assortment of quality outdoor equipment for camping, hiking and other recreational activities -- always at Wal-Mart's Every Day Low Prices!Weatherproof: GoBeDry for all-weather protection Dimensions: 9.5' L x 10' W x 4.9' H Features: 3 free-standing tents, door mat, expandable carry bag Size: Sleeps 9-10 Model No.: WMT-5200 Shipping Weight (in pounds): 26.9 Product in Inches (L x W x H): 114.0 x 120.0 x 59.0 Assembled in Country of Origin: Imported Origin of Components: Imported Wal-Mart No.: 000987967 Link to comment Share on other sites More sharing options...
alaskajoel Posted June 8, 2008 Share Posted June 8, 2008 *votes for anderson's old avatar* Oh, and i've been looking for a good tent. Thanks! Link to comment Share on other sites More sharing options...
andrew.anderson Posted June 8, 2008 Author Share Posted June 8, 2008 *votes for anderson's old avatar* Oh, and i've been looking for a good tent. Thanks! Here's another. $79.99 Wenzel Big Piney 2 Room 16 x 8-Foot Family Tent http://www.amazon.com/gp/product/images/B000HBXHGG/ref=dp_images_0?ie=UTF8&s=sporting-goods&img=0&childASIN=B000HBXHGG Product Features * Family Dome Sleeps 6 comfortably in 116 square foot of space * Base, floor is 16 feet long by 8 feet wide with a center height of 74" for standing pleasure * Back -to-back Dutch "D" style doors for easy tent access * Hanging divider curtain creates two separate rooms, each with its own door * Removable fly with hoop frame over front door and rear window Link to comment Share on other sites More sharing options...
andrew.anderson Posted June 13, 2008 Author Share Posted June 13, 2008 $149.99 Barebones Kit - v7.0, Intel Pentium D 940 3.0GHz OEM, 2GB DDR2 PC6400, ATX Mid-Tower Case, 450 Watt Power Supply http://images.tigerdirect.com/skuimages/large/TC3J-4030-P-main.jpg Specifications Processor Speed: 940 / 3.20GHz Form Factor: microATX Memory Size: 2 x 1024MB Form Factor: ATX Mid-Tower Compatible Motherboards: ATX Micro ATX Processor Interface: Socket 775 Memory Speed: 800MHz PC6400 Processor Interface: Socket 775 Processor Class: Pentium D Processors Supported: Intel Pentium 4 LGA775 Intel Pentium D Intel Core 2 Duo Memory CAS Latency: 4-4-4-15 Processors Supported: Intel Celeron D 4XX, Intel Pentium Dual Core Memory Type: Dual Channel DDR2 Processor Core: Presler Side Panel Type: Vented Front Side Bus: 1066MHz Cache Size: 4MB L2 Pins: 240 Front Side Bus: 533MHz 800MHz Power Supply: 450 Watt Bus Speed: 800MHz Additional Technologies: Enhanced Halt State Execute Disable Bit Intel® Virtualization Dual-Core Enhanced Intel Speedstep Intel® EM64T Material: Steel Architecture: 65 nm Wattage: 95W Core Stepping: C1 Fan: Not Included Northbridge: VIA P4M900 External 5.25" Drive Bays: 4 Southbridge: VIA VT8237A External 3.5" Drive Bays: 1 Internal 3.5" Drive Bays: 5 Expansion Slots: 7 Number of Slots: 2 Front USB Ports: 2 Number of Pins: 240-Pin Maximum Memory Supported: 4GB Front Audio Ports: 2 Memory Supported: 400MHz DDR2 533MHz DDR2 667MHz DDR2 120mm Fan Ports: 1 120mm Fans Included: None Video Chipset: VIA Chrome9 HC IGP Video Memory: 256MB Share Memory Supported Devices: 2 Hard Drive Types: UDMA/33 UDMA/133 UDMA/100 UDMA/66 USB Version: 2.0 USB Data Transfer Rates: 480Mbps LAN Type: 10/100Mbps Port Type: RJ-45 PCI Slots: 2 PCI Express X1 Slots: 1 PCI Express X16 Slots: 1 PS/2 Keyboard Connectors: 1 PS/2 Mouse Connectors: 1 Serial Communication Ports: 1 USB Ports: 8 LAN Ports: 1 Audio Out Jacks: 1 Line In Jacks: 1 Microphone Jacks: 1 CD-In Headers: 1 IDE Headers: 1 FDD Headers: 1 Serial ATA Headers: 2 ATX Power Connectors: 1 24-Pin Connector PC Power Connectors: 1 - 4 Pin VGA Ports: 1 Length: 9.598 in. (24.38 cm) Width: 7.500 in. (19.0 cm) Link to comment Share on other sites More sharing options...
icrackedcorn Posted June 14, 2008 Share Posted June 14, 2008 (edited) ZOMG must buy that computer edit- hmmm. perhaps not Edited June 14, 2008 by icrackedcorn obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
andrew.anderson Posted June 15, 2008 Author Share Posted June 15, 2008 ZOMG must buy that computer edit- hmmm. perhaps not Only a good deal if you are willing/able to build your own and do your own tech support. Link to comment Share on other sites More sharing options...
icrackedcorn Posted June 15, 2008 Share Posted June 15, 2008 Only a good deal if you are willing/able to build your own and do your own tech support. ill be building my next tower, i just saw a pretty quick chip (albiet older architecture) and for the price, damn. but while im at it, ill be looking into crossfire/sli capability and plenty of other nerdy overkill specs obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
andrew.anderson Posted June 15, 2008 Author Share Posted June 15, 2008 ill be building my next tower, i just saw a pretty quick chip (albiet older architecture) and for the price, damn. but while im at it, ill be looking into crossfire/sli capability and plenty of other nerdy overkill specs If you are willing to share I would be interested in your research / progress. If you start a thread on here tracking your research, cost analysis and then build I would follow it. Not sure if there are alot of others on here interested in computers but I know there are a few prominent members that are in the CS/IT field. Link to comment Share on other sites More sharing options...
icrackedcorn Posted June 16, 2008 Share Posted June 16, 2008 If you are willing to share I would be interested in your research / progress. If you start a thread on here tracking your research, cost analysis and then build I would follow it. Not sure if there are alot of others on here interested in computers but I know there are a few prominent members that are in the CS/IT field. will do obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
andrew.anderson Posted June 16, 2008 Author Share Posted June 16, 2008 will do Pm me the thread link or post it in one or all of the below threads: http://legacygt.com/forums/showthread.php?t=76341 http://legacygt.com/forums/showthread.php?t=30363 http://legacygt.com/forums/showthread.php?t=17371 Link to comment Share on other sites More sharing options...
andrew.anderson Posted June 16, 2008 Author Share Posted June 16, 2008 $4.99 DVDs at Best Buy Link to comment Share on other sites More sharing options...
andrew.anderson Posted June 16, 2008 Author Share Posted June 16, 2008 This is a great deal. If my laptop was not so old I would buy some of this. http://legacygt.com/forums/images/icons/icon9.gif $12.98 Kingston 1GB PC2-5300 667MHz 200-pin SO-DIMM DDR2 Laptop Memory http://ak.buy.com/db_assets/prod_lrg_images/016/204884016.jpg Features http://ak.buy.com/buy_assets/v6/july/dot2.gifMemory Size 1GB http://ak.buy.com/buy_assets/v6/july/dot2.gifManufacturer Kingston Technology Company http://ak.buy.com/buy_assets/v6/july/dot2.gifMemory Technology DDR2 SDRAM http://ak.buy.com/buy_assets/v6/july/dot2.gifManufacturer Part Number KVR667D2SO/1GRhttp://ak.buy.com/buy_assets/v6/july/dot2.gifStandard Warranty Lifetime Limited http://ak.buy.com/buy_assets/v6/july/dot2.gifForm Factor SoDIMM http://ak.buy.com/buy_assets/v6/july/dot2.gifManufacturer Website Address www.kingston.com http://ak.buy.com/buy_assets/v6/july/dot2.gifMemory Speed 667MHz DDR2-667/PC2-5300 http://ak.buy.com/buy_assets/v6/july/dot2.gifProduct Line ValueRAM http://ak.buy.com/buy_assets/v6/july/dot2.gifProduct Name ValueRAM 1GB DDR2 SDRAM Memory Module http://ak.buy.com/buy_assets/v6/july/dot2.gifProduct Type RAM Module Link to comment Share on other sites More sharing options...
andrew.anderson Posted June 16, 2008 Author Share Posted June 16, 2008 $14.99 2GB DDR2 PC6400 DUAL MEMORY (2X1GB) / CRUCIAL http://images.frys.com/art/product/box_shots/5527130.box.GIF Detailed Description DDR2 PC2-6400 CL=6 Unbuffered NON-ECC DDR2-800 1.8V 128Meg x 64 Link to comment Share on other sites More sharing options...
andrew.anderson Posted June 21, 2008 Author Share Posted June 21, 2008 2 DVD's for $10 http://images.bestbuy.com/BestBuy_US//en_US/images/abn/2008/mm/pcon/f_2f10dvd080615_03.jpg Link to comment Share on other sites More sharing options...
BigInALegacy Posted June 21, 2008 Share Posted June 21, 2008 (edited) http://c1.neweggimages.com/NeweggImage/ProductImageCompressAll125/20-171-345-01.jpg http://c1.neweggimages.com/Brandimage_70x28/Brand1404.gif http://c1.neweggimages.com/WebResource/Themes/2005/Nest/flamingEgg.gifhttp://c1.neweggimages.com/WebResource/Themes/2005/Nest/iconCombo.gifhttp://c1.neweggimages.com/WebResource/Themes/2005/Nest/none.gifhttp://c1.neweggimages.com/WebResource/Themes/2005/Nest/none.gif SanDisk 2GB Memory Stick Micro (M2) Flash Card - Retail Model SDMSM22048A11M 2GB Read/write: 10MB/sec read, ...\\$$17.99 http://images17.newegg.com/is/image/newegg/30-120-261-TS?$S125W$ http://c1.neweggimages.com/Brandimage_70x28/Brand1213.gif http://c1.neweggimages.com/WebResource/Themes/2005/Nest/bargains.gifhttp://c1.neweggimages.com/WebResource/Themes/2005/Nest/iconCombo.gifhttp://c1.neweggimages.com/WebResource/Themes/2005/Nest/none.gifhttp://c1.neweggimages.com/WebResource/Themes/2005/Nest/none.gif Free A-Data SD card w/ purchase, while supplies last Canon PowerShot A470 Orange 7.1 MP Digital Camera 1/2.5" CCD 2.5" 115K LCD 3.4X Optical Zoom 4X Digital ... http://c1.neweggimages.com/WebResource/Themes/2005/Nest/goldegg.gifhttp://c1.neweggimages.com/WebResource/Themes/2005/Nest/goldegg.gifhttp://c1.neweggimages.com/WebResource/Themes/2005/Nest/goldegg.gifhttp://c1.neweggimages.com/WebResource/Themes/2005/Nest/goldegg.gifhttp://c1.neweggimages.com/WebResource/Themes/2005/Nest/goldegg.gif [3]More: http://www.newegg.com/DailyDeal.aspx?page=3 $102.99 Edited June 21, 2008 by BigInALegacy Link to comment Share on other sites More sharing options...
andrew.anderson Posted June 21, 2008 Author Share Posted June 21, 2008 $8.45 Kingston 2GB MicroSD Flash Card Model SDC http://c1.neweggimages.com/NeweggImage/productimage/20-134-597-03.jpg Link to comment Share on other sites More sharing options...
