leggtnut Posted February 25, 2009 Share Posted February 25, 2009 When you do it that way, you never have to do the, where the F is that install disk. I keep mis-placing them and if I just copy the contents to my file server, I don't have to worry. I even make a text file in the directory that holds the CD key. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
TSiWRX Posted February 26, 2009 Share Posted February 26, 2009 The Acer Netbook does just fine with ECUTeK's software. Thanks, a.a. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Abandonhope16 Posted February 26, 2009 Share Posted February 26, 2009 Amazon now has the black HE in stock for those interested. They've been pretty backlogged since its release. Link to comment Share on other sites More sharing options...
andrew.anderson Posted February 27, 2009 Author Share Posted February 27, 2009 $199 Dell Inspiron Mini 9 http://www.bargainist.com/deals/images/2009/02/dell-inspiron-mini.jpg Link to comment Share on other sites More sharing options...
andrew.anderson Posted February 27, 2009 Author Share Posted February 27, 2009 (edited) $21.99 Patriot 2GB 200-Pin DDR2 SO-DIMM DDR2 800 (PC2 6400) Laptop Memory http://c1.neweggimages.com/NeweggImage/productimage/20-220-281-04.jpg Model Brand Patriot Model PSD22G8002S Type 200-Pin DDR2 SO-DIMM Tech Spec Capacity 2GB Speed DDR2 800 (PC2 6400) Cas Latency 5 Voltage 1.8V ECC No Buffered/Registered Unbuffered Heat Spreader No Edited February 27, 2009 by andrew.anderson Link to comment Share on other sites More sharing options...
andrew.anderson Posted February 27, 2009 Author Share Posted February 27, 2009 $19.99 D-Link Express EtherNetwork DP-301U Print Server http://ak.buy.com/db_assets/prod_lrg_images/139/10345139.jpg Features Compact size for flexible placement Easy configuration using the Web-based setup utility USB 2.0 port for compatible Hi-speed printers Tech Specs IEEE 802.2 IEEE 802.3 IEEE 802.3u USB 2.0/1.1 10/100Mbps Fast Ethernet USB 2.0 Port TCP/IP NetBEUI AppleTalk/EtherTalk BOOTP SNMP Telnet TFTP FTP LPD RARP DHCP Management SNMP MIBs MIB-II (RFC 1213) Power Link/Activity USB External Power Supply DC 5V, 2.5A Item (WxDxH): 3.19” x 3.54” x 1.57” 0.27 lbs (121g) Operating: 32°F to 122°F (0° to 50°C) Storage: -13°F to 131°F (-25° to 55°C) 5% ~ 95% Maximum (Non-condensing) 1 Year Limited Windows Vista®, Windows® XP SP2, Windows 2000 SP4, or Mac OS® X (v10.2/v10.3) Printer with USB Connection Link to comment Share on other sites More sharing options...
TPLGT Posted February 27, 2009 Share Posted February 27, 2009 So I have bascially narrowed it down to 1 of 2 netbooks: http://www.newegg.com/Product/Product.aspx?Item=N82E16834147824 OR http://www.newegg.com/Product/Product.aspx?Item=N82E16834115551 Is it worth the extra $50 for the HP? The Acer has another 100G HD but I will never even use the 60G on the HP. From what I ahve read, the Acer is decent but the HP is better 'feeling' over all. Anyone have any thoughts? Rehab is for quitters. Link to comment Share on other sites More sharing options...
Abandonhope16 Posted February 27, 2009 Share Posted February 27, 2009 I would still recommend the 1000HE. $343 (with MS Cashback) shipped from J&R. Has the slightly updated processor and is easier to perform a RAM upgrade than the Acer; plus a 9.5 hour battery. Link to comment Share on other sites More sharing options...
TPLGT Posted February 27, 2009 Share Posted February 27, 2009 They do not list the HE just the HA... Rehab is for quitters. Link to comment Share on other sites More sharing options...
Abandonhope16 Posted February 27, 2009 Share Posted February 27, 2009 Also available in Blue. J&R is cheaper (but Amazon has it now). [ame=http://www.amazon.com/10-Inch-Netbook-Processor-Storage-Bluetooth/dp/B001QTXL82/ref=pd_bbs_sr_1?ie=UTF8&s=electronics&qid=1235772255&sr=8-1]Amazon.com: ASUS Eee PC 1000HE 10-Inch Netbook (1.66 GHz Intel Atom N280 Processor, 1 GB RAM, 160 GB Hard Drive, 10 GB Eee Storage, Bluetooth, XP Home, 9.5 Hour Battery Life) Black: Electronics[/ame] Link to comment Share on other sites More sharing options...
Abandonhope16 Posted February 27, 2009 Share Posted February 27, 2009 Also on Newegg, but they are charging list; while other vendors are still charging the pre-order "special" price. http://www.newegg.com/Product/Product.aspx?Item=N82E16834220504 Link to comment Share on other sites More sharing options...
andrew.anderson Posted March 6, 2009 Author Share Posted March 6, 2009 $199 Asus Eee PC 900 Netbook Celeron M 900MHz Processor 512MB RAM, 4GB SSD 8.9" LCD Linux OS -Black http://ak.buy.com/db_assets/large_images/798/210826798.jpg Features Asus Eee PC 900 Celeron M 900 MHz 8.9-inch Notebook General Features: Color: Galaxy Black Asus customized Linux operating system Intel Celeron M 900 MHz processor 512 MB RAM 4 GB Solid State (SSD) Hard Drive Integrated audio with built-in speakers Integrated 10/100 Ethernet 802.11b/g Wireless LAN Keyboard with TouchPad Built-in Memory Card Reader 8.9-inch LCD display (1024 x 600 resolution) Supported Media: MultiMedia Card (MMC) Secure Digital (SD) I/O ports: Three (3) USB 2.0 ports RJ-45 Ethernet port One (1) 15-pin VGA port Microphone jack Headphone jack Dimensions: 7 x 8.75 x 6.6-inches (H x W x D, approximate) Regulatory Approvals: FCC CE VCCI C-Tick cULus MIC Link to comment Share on other sites More sharing options...
TPLGT Posted March 7, 2009 Share Posted March 7, 2009 Nice deal!^^^^^ I have set my sights on a 10"....looks like the ASUS 1000he is the deal...still about $375 SHIPPED...if you can find them in stock....HPs are non-existent. Rehab is for quitters. Link to comment Share on other sites More sharing options...
j255c Posted March 7, 2009 Share Posted March 7, 2009 just received my eee pc, awesome little machine. Absoultely perfect for logging and browsing the net. Still would not use it as main computer though honestly. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
TPLGT Posted March 7, 2009 Share Posted March 7, 2009 just received my eee pc, awesome little machine. Absoultely perfect for logging and browsing the net. Still would not use it as main computer though honestly. The 1000HE? I was looking at the nerd thread...seems like you guys are happy w/ the ASUS. Rehab is for quitters. Link to comment Share on other sites More sharing options...
j255c Posted March 7, 2009 Share Posted March 7, 2009 ^yup im pleasantly surprised with the quality. Here's a snapshot of my desktop on the eee pc . I reverted the theme back to classic mode, have my sidebar with main applications, and winbar uptop to display cpu usage ram use dl/up rates,etc. Resolution is 1024*600, as you can see in the winbar application on the top ram usage is already at 700/1015 http://i67.photobucket.com/albums/h300/c0lbyj/asuseeedesktop.jpg 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
andrew.anderson Posted March 7, 2009 Author Share Posted March 7, 2009 ^yup im pleasantly surprised with the quality. Here's a snapshot of my desktop on the eee pc . I reverted the theme back to classic mode, have my sidebar with main applications, and winbar uptop to display cpu usage ram use dl/up rates,etc. Resolution is 1024*600, as you can see in the winbar application on the top ram usage is already at 700/1015 http://i67.photobucket.com/albums/h300/c0lbyj/asuseeedesktop.jpg Is the Max RAM in that one 1.5 or 2.0 GB? Link to comment Share on other sites More sharing options...
j255c Posted March 7, 2009 Share Posted March 7, 2009 (edited) it comes with a 1gb stick stock, there are 2gb sticks you can upgrade too for $25 as discussed in the other thread. Edited March 7, 2009 by j255c 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
andrew.anderson Posted March 10, 2009 Author Share Posted March 10, 2009 $239.97 Acer Aspire One AOA150-1777 Refurbished Netbook - Intel Atom™ Processor N270 1.6GHz, 1GB DDR2, 120GB HDD, 8.9" WSVGA, Windows® XP Home, Sapphire Blue http://images.tigerdirect.com/itemdetails/S445-89001/S445-89001-call07-maf.jpg Specifications: Lifestyle: Netbooks Condition: Refurbished Operating Systems: Windows XP Home Startup Operating System: Microsoft® Windows® XP Home Platform: Netbook Expansion Ports: 1 - SD Card Slot Display Type: WSVGA with CrystalBrite Technology Screen Size: 8.9" Maximum Resolution: 1024 x 600 Processor Brand: Intel Processor Class: Atom Processor Speed: 1.60GHz Processor Number: N270 Processor FSB: 533MHz Processor Cache: 512KB Memory Type: DDR2 Memory Size: 1GB Memory Speed: DDR2 533 Memory Slots (Total): 1 Memory Slots (Available): 0 Maximum Memory Supported: 1.5GB Graphics Description: Integrated Graphics GPU/VPU: Intel® Graphics Media Accelerator 950 Video Interface: VGA Capacity: 120GB Optical Drive Type: N/A Supplemental Drive Type: Media Reader Media Types: SecureDigital Memory Stick xD-Picture Card Memory Stick PRO Multi Media Card Reduced-Size Multi Media Card Capacity: 1 Media Types: SecureDigital Audio Description: Integrated Audio Audio Chipset: Hi-Definition (HD) Audio Support PS/2 Mouse Connectors: N/A PS/2 Keyboard Connectors: N/A Serial Communication Ports: N/A Parallel Ports: N/A USB Ports: 3 FireWire Ports: N/A Fast Infrared Ports (FIR): N/A LAN Ports: 1 Modem Ports: N/A Audio Out Jacks: 1 Line In Jacks: N/A Microphone Jacks: 1 VGA Ports: 1 Communications Description: Integrated LAN Integrated Wireless LAN Interface Type: RJ-45 Ethernet Connector Acer InviLink 802.11b/g wireless LAN Data Transfer Rate: 10/100Mbps NIC 54 Mbps Protocols: WIFI 802.11b 802.11g Width: 9.8" 249 mm Height: 29 mm 1.14" Depth: 6.7", 170 mm Weight: 2.3 lbs 1.04 kg Keyboard Type: 84-key Keyboard Battery Type: 3-Cell Lithium-ion Battery Life: Up to 2.5 hours Link to comment Share on other sites More sharing options...
Spec B Posted March 10, 2009 Share Posted March 10, 2009 ^ i got one...perfect for email/internets/logging/flashing. Link to comment Share on other sites More sharing options...
andrew.anderson Posted March 10, 2009 Author Share Posted March 10, 2009 When it arrives you should post up how you like it. I have been away quite a bit but we used to have a Netbook thread on here. I will go look for it. Link to comment Share on other sites More sharing options...
Abandonhope16 Posted March 10, 2009 Share Posted March 10, 2009 Nice deal!^^^^^ I have set my sights on a 10"....looks like the ASUS 1000he is the deal...still about $375 SHIPPED...if you can find them in stock....HPs are non-existent. Amazon has them in stock regularly. J&R is still the best deal with the 6% cashback rebate; but out of stock (you can still order and get the rebate though). It is really neat, the build quality is much better than I expected; but a little bit heavier than anticipated, still half the weight of my Dell laptop. I wasnt originally going to upgrade the RAM, but to double memory for $25 is a great deal; so I'll be ordering that soon. Link to comment Share on other sites More sharing options...
2006Specb122 Posted March 10, 2009 Share Posted March 10, 2009 I'm about to spring on the Jet Black Dell Inspiron 15 for the wife. Best Buy 649. They were 599 but price went up last month. Looks like a good machine for the price of an access port. Thought about a mini but the wife hated the smaller size. (She is used to BIG things) Tried building a very similar setup on Dell's web site and the price came out to 827. They have worked out some good pricing on those pre packaged systems. Link to comment Share on other sites More sharing options...
Abandonhope16 Posted March 10, 2009 Share Posted March 10, 2009 Thought about a mini but the wife hated the smaller size. (She is used to BIG things) Then why is she with you. Come on; too easy Link to comment Share on other sites More sharing options...
2006Specb122 Posted March 10, 2009 Share Posted March 10, 2009 NOVA, Who is the hottie in your avatar.... Link to comment Share on other sites More sharing options...
