Alain969 Posted November 9, 2007 Share Posted November 9, 2007 Do anybody tranfert DRL for works whith the hight beam? Sorry for my english! Link to comment Share on other sites More sharing options...
RaGe Posted November 9, 2007 Share Posted November 9, 2007 i am not understanding your question. OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
andrew.anderson Posted November 9, 2007 Share Posted November 9, 2007 I believe he wants to be ableto have his DRLs and High Beams on at the same time. Link to comment Share on other sites More sharing options...
Neurodancer Posted November 9, 2007 Share Posted November 9, 2007 I think he wants it set up like the 08s -> DRLs are a dimmed high beam vs. using the standard headlights. I think Subie made this change with the new model year because of the shortened lifespan of 05-07 driving lights... Link to comment Share on other sites More sharing options...
laz Posted November 9, 2007 Share Posted November 9, 2007 I tried it once but the high beams are too bright. There is no easy way to make them dimmer either. X --- Link to comment Share on other sites More sharing options...
NutBucket Posted November 9, 2007 Share Posted November 9, 2007 You could unplug the stock DRL module and grab an aftermarket DRL module from ebay and hook up your high beams with that. Link to comment Share on other sites More sharing options...
laz Posted November 9, 2007 Share Posted November 9, 2007 Does the aftermarket module lower the poower to the high beams? Also our lights are negative switched. X --- Link to comment Share on other sites More sharing options...
lookslikeanevo Posted November 9, 2007 Share Posted November 9, 2007 Does the aftermarket module lower the poower to the high beams? Also our lights are negative switched. X lower output is dependent on the bulb....what size bulbs are the 08 guys using stock? Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
NutBucket Posted November 9, 2007 Share Posted November 9, 2007 Yes, the modules are designed to do exactly that. Link to comment Share on other sites More sharing options...
laz Posted November 9, 2007 Share Posted November 9, 2007 lower output is dependent on the bulb....what size bulbs are the 08 guys using stock? Not when you are talking about high beams. They are regular 60 Watt high beams, but are lowered by the DRL module. X --- Link to comment Share on other sites More sharing options...
laz Posted November 9, 2007 Share Posted November 9, 2007 Yes, the modules are designed to do exactly that. That is interesting. Do you have a linky link? X --- Link to comment Share on other sites More sharing options...
NutBucket Posted November 9, 2007 Share Posted November 9, 2007 What the h3ll? There used to be hundreds of these things on ebay. Now not even 1? This one would work. Supposedly has functionality very similar to the stock setup as well. http://cgi.ebay.com/ebaymotors/ac-delco-daytime-running-lamps-12370445-nib_W0QQitemZ320178776244QQihZ011QQcategoryZ50459QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Link to comment Share on other sites More sharing options...
laz Posted November 9, 2007 Share Posted November 9, 2007 Ah nice thanks! Probably what I needed when I tried this little project a couple of years ago. X --- Link to comment Share on other sites More sharing options...
Alain969 Posted November 10, 2007 Author Share Posted November 10, 2007 This is it, the stock DRL is on low beam and i want it on the high beam only.because i install the kit xenon on my low beam. I want the DRL because its the law in canada. Anybody try this? thanks Link to comment Share on other sites More sharing options...
laz Posted November 10, 2007 Share Posted November 10, 2007 Thanks for the helpful comment Seb! X --- Link to comment Share on other sites More sharing options...
outahere Posted November 10, 2007 Share Posted November 10, 2007 This is it, the stock DRL is on low beam and i want it on the high beam only.because i install the kit xenon on my low beam. I want the DRL because its the law in canada. Anybody try this? thanks Aren't you legally allowed to use the fog lights as DRL in Canada? Link to comment Share on other sites More sharing options...
outahere Posted November 10, 2007 Share Posted November 10, 2007 I tried it once but the high beams are too bright. There is no easy way to make them dimmer either. X Have you tried running the high beams in series, to get about 7V to each bulb? Link to comment Share on other sites More sharing options...
laz Posted November 11, 2007 Share Posted November 11, 2007 Have you tried running the high beams in series, to get about 7V to each bulb? I did not try since I was not about to run extra wiring. I wanted to use the OEM wiring. Anyway, it was to bright, and I took it off. X --- Link to comment Share on other sites More sharing options...
underpowerd Posted November 11, 2007 Share Posted November 11, 2007 anyone comes across a p/n for the oe module (or any other well-detailed way) to get this to run, plz post; ty. Link to comment Share on other sites More sharing options...
lookslikeanevo Posted November 15, 2007 Share Posted November 15, 2007 HID REtores FTMFW! Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
Apex-XT Posted March 23, 2008 Share Posted March 23, 2008 This is a bump for the High Beam DRL conversion activity that was going on. Anyone gotten any further with this? I'm about to install my HIDs, don't really want to use fogs, and am running HIRs in the high beam. I don't want to run the HIRs at full voltage because, well, they're expensive and I'd rather not burn them as high if I don't need to. I may just do the independent fog light mod with the HIDs and only turn the fogs on if I need them. And to h3ll with DRLs... 300k miles, BNR 16g, CryoTune, 'Bullet-Proofed' IC, Motor rebuild @ 250k b/c of a cracked exhaust valve. Original 5 EAT. Oil changed religiously @ 3,000 mi. Link to comment Share on other sites More sharing options...
underpowerd Posted March 23, 2008 Share Posted March 23, 2008 ^good luck (there's a dup of this thread i bumped a few times to no avail) i've found scrapping drls is not so bad, but i'm still up for getting into some wires if an electrical guru can walkthru high-beam drls on 05-07. i just cant get into the idea of drl fogs. Link to comment Share on other sites More sharing options...
Apex-XT Posted March 25, 2008 Share Posted March 25, 2008 Glad you agree! Not sure if anyone else has tried the HIRs in their high beams yet. I'm pretty happy with them. Basically, you file off a small portion of the skirt tabs and it fits perfectly into your existing high beam socket. HIR = High-intensity Infrared Reflectance - it's a weird shaped bulb - has a globe on the end around the filament. The IR energy from the filament is reflected back off of the the inside of the globe, contributing to the heat of the filament which makes it burn much brighter. The only downside is the bulb is about $35-40 each. At that cost, I don't want to use them for DRLs. There's a good sticky by Daniel Stern in this forum that talks about lighting options that describes them better. 300k miles, BNR 16g, CryoTune, 'Bullet-Proofed' IC, Motor rebuild @ 250k b/c of a cracked exhaust valve. Original 5 EAT. Oil changed religiously @ 3,000 mi. Link to comment Share on other sites More sharing options...
