Xenonk Posted February 13, 2005 Share Posted February 13, 2005 but dude, it sounds soo cool.. especially if you have a turboback exhuast... brings back some memories of old muscle cars with rough idling.. sooo awesome.. Keefe Keefe Link to comment Share on other sites More sharing options...
melayout Posted August 10, 2005 Share Posted August 10, 2005 Whooptydoo, Got a lumpy shake. It is very severe when stopped at lights in D mode. Then a steady CEL came on, but thank god Autozone was nearby and open, so I pulled the codes and it was 2 instances for P0302 - Cylinder #2 misfire. Bad gas? Faulty injector? Wazzaaaap?!!!! Is it ok to drive to the dealer with a cylinder misfire? I keed I keeed Link to comment Share on other sites More sharing options...
melayout Posted August 12, 2005 Share Posted August 12, 2005 Went to dealer, turns out all the spark plugs were fouled/electrode burned up. He said knowing how hard I drive, he said it was normal. Is that correct? Plus they replaced them under the basic warranty, sweeeet. Edit: Attached Spark Plug PDF, very informative.02 - Spark Plug.pdf02 - Spark Plug.pdf I keed I keeed Link to comment Share on other sites More sharing options...
Outback XT Posted August 12, 2005 Share Posted August 12, 2005 I noticed only a minor normal shake until yesterday. I had my car in for warranty work in replacing my clutch. Now it shakes a bit more. Not sure what happened??? Link to comment Share on other sites More sharing options...
melayout Posted August 12, 2005 Share Posted August 12, 2005 How many miles do you have and would you say you're on boost 24/7 ? I keed I keeed Link to comment Share on other sites More sharing options...
RockyMtnGT Posted August 12, 2005 Share Posted August 12, 2005 My 97 Outback (basically the same 2.5 engine without the turbo) had the same occasional shake from day 1 until 148,000 miles when I traded it in....I wouldn't worry too much about it IMO Link to comment Share on other sites More sharing options...
dan_m Posted August 15, 2005 Share Posted August 15, 2005 Actually, they run on 6 pistons, so the resonance is less noticable. Keefe +1 the smoothest engines all come in multiples of 6 Link to comment Share on other sites More sharing options...
Deer Killer Posted August 15, 2005 Share Posted August 15, 2005 lol.. I said it was running lean 6 months ago.. I'm pretty damn sure of it now.. the ECU's running closed loop fuel/timing trying to be exactly stoichiometric.. duh.. that's the problem. Link to comment Share on other sites More sharing options...
jj808 Posted August 15, 2005 Share Posted August 15, 2005 My car idles rough fm the moment it warms up till the moment i turn it off. It honestly feels like i have a v8 under the hood. I dont see the rpms jumping but the factory gauge isnt that precise. Link to comment Share on other sites More sharing options...
Leonardo Posted August 24, 2005 Share Posted August 24, 2005 Mine started yesterday. Got Cyl 4 misfire. Related? who knows! I only have up-pipe, drop in filter and Lachute mufflers. Link to comment Share on other sites More sharing options...
Leonardo Posted August 24, 2005 Share Posted August 24, 2005 Ne1? Link to comment Share on other sites More sharing options...
Leonardo Posted August 24, 2005 Share Posted August 24, 2005 My car idles rough fm the moment it warms up till the moment i turn it off. It honestly feels like i have a v8 under the hood. I dont see the rpms jumping but the factory gauge isnt that precise. Same here! FOr the ones with rough idle, WHat are your mods or at least intake? Link to comment Share on other sites More sharing options...
melayout Posted August 24, 2005 Share Posted August 24, 2005 How many miles do you have? Is your drop-in filter the oiled/reusable type or not? I keed I keeed Link to comment Share on other sites More sharing options...
Leonardo Posted August 24, 2005 Share Posted August 24, 2005 Like 7k milles! I have the Perrin (oiled) drop in filter. Thought about taking out the MAF and throwing a little Brake Cleaner to see if it helps any. Link to comment Share on other sites More sharing options...
jah64 Posted August 25, 2005 Share Posted August 25, 2005 I just had the car serviced for warranty issues, headlight, trunk latch, trunk floor hook blah blah blah. They also figured out why my car Idled rough ->misfire code, BAD INJECTOR. New one is on order. will report back when they replace it. Link to comment Share on other sites More sharing options...
Subaguru Posted August 25, 2005 Share Posted August 25, 2005 So after 30,000 miles on my GT 5MS, it started to shake violently on the highway in traffic. I don't mean the "boxer idle", I mean like the engine was going to fall out.. Any of these posts in regards to something of this nature? It did it randomly 3-4 times and lasted for 1-3 minutes each time, lasting longer on the later times. Any clues? Link to comment Share on other sites More sharing options...
Erickson00 Posted August 26, 2005 Share Posted August 26, 2005 My car has a rough idle. It's not a big deal when the AC is off, but as soon as i switch it on, the idle becomes much more noticeable. What's worse is the way it drives in low RPMs with the AC on. If I throw down 75% or more throttle, it behaves pretty well. However, during normal driving with 25% to 50% throttle, the car does not behave well. The acceleration does not feel smooth through the pedal. I can feel hesitation throughout the climb in RPMs until they get to around 3,800, which is where I normally shift during casual driving. When I do shift, it feels as though the car nose dives when I release the clutch; a dramatic decrease in power. It's not smooth, like I've experienced in other cars. It's enough of a jerk to move my body a bit forward in my seat. This probably a different issue, but it seems related to the idle issue. When my AC is on, the car's idle, acceleration, and shifting behavior are very suspect. I don't really know what to do. I've tried fuel injector cleaner. I have never put anything but 93 octane gas in it, and I've shopped around at different gas stations to make sure it wasn't a fuel problem (even though this only occurs when the AC is, which narrows down the problem and indicates it's not a fuel or injector issue). I have 4,700 miles on the car, and no upgrades, except for a new ECU. They tried to reflash mine a while back and it made the stuttering worse, so they ordered a brand new ECU. Could that be the problem? It's enough of an issue that it bothers me every day. Link to comment Share on other sites More sharing options...
Leonardo Posted August 27, 2005 Share Posted August 27, 2005 I feel ya! Feels nice when you turn on the car UNTILL you touch the gas and the cold start goes away. I was wondering if it were something with the mixture as when I start the car, since I have Lachute mufflers (free flow) the car seems increddibly ritch. Also have gotten a seconf Cyl 4 Missfire code (0304) when I leave it standing for a while. Link to comment Share on other sites More sharing options...
