mcsquish Posted November 1, 2007 Share Posted November 1, 2007 I have an idea that in theory should work (we all know how that works), but can't figure out if it is possible. After the last batch of fog that I drove through, I really hate not being able to turn on just the fog-lights and parking lights. I am going to do the fog-light mod, but I really don't want to disconnect the DRL. So I began to wonder if it is possible to make the switch for the parking lights, that is on the steering column, into a switch that would turn off the DRL when you turn on the parking lights. I have searched to see if anyone else has tried this and looked through the photos from my 2005 vacation, but I am not an electrical person........If I tried to figure it out alone, when I flipped the switch, the back window of my LGT wagon might go up and down....... Link to comment Share on other sites More sharing options...
laz Posted November 1, 2007 Share Posted November 1, 2007 Yu will be able to do this with a relay and some wire tapping. Basically have the relay open the circuit to the cable that does DRL's when the parking lights are on. X --- Link to comment Share on other sites More sharing options...
outahere Posted November 1, 2007 Share Posted November 1, 2007 .....So I began to wonder if it is possible to make the switch for the parking lights, that is on the steering column, into a switch that would turn off the DRL when you turn on the parking lights. ..... Yes, I have done something like that. I disconnected this switch from the parking light circuit, and use it to control a relay, which controls the DRLs. In one position, the DRLs operate normally, in the other position, the DRLs are always off. Link to comment Share on other sites More sharing options...
