JonLGT Posted October 31, 2007 Share Posted October 31, 2007 Yes, I read the sticky a million times and I still have a question. I found a beautiful set of Advan RGIIs for my legacy at a killer price. The size is 18"x8" with a +40 offset, which leads me to my question... Will it work without sticking past the fenders? I ran 18x8.5s with a +46 with a bit of room to spare, just want to make sure they wont stick out and look rediculous (in a bad way) before I spend the money. I apreciate the help. Yes I read the sticky! Link to comment Share on other sites More sharing options...
boostsr20 Posted October 31, 2007 Share Posted October 31, 2007 If your running a 225/40/18 you won't have to worry. Anything wider and you'd be pushing it. Is the car lowered? If its lowered the negative camber will help it appear to be inside the well at the top. Link to comment Share on other sites More sharing options...
JonLGT Posted October 31, 2007 Author Share Posted October 31, 2007 Yes lowered on S-techs. Link to comment Share on other sites More sharing options...
JonLGT Posted October 31, 2007 Author Share Posted October 31, 2007 Anyone else? Link to comment Share on other sites More sharing options...
JonLGT Posted October 31, 2007 Author Share Posted October 31, 2007 Help! Link to comment Share on other sites More sharing options...
JonLGT Posted October 31, 2007 Author Share Posted October 31, 2007 Help before I pay $2k for these and they dont work! Link to comment Share on other sites More sharing options...
boostsr20 Posted November 1, 2007 Share Posted November 1, 2007 Now that I think about it, that might be a tad too much offset. I believe Keefe in teh past had soem 17x8 et 40 that he put some 235/40 rubber on. Maybe he'll chime in but I don't think these are going to be the look you want. 18x8 et40 will move the wheel 1.1 inches out from the car. If you've got stockers you can go measure and see what you think. Link to comment Share on other sites More sharing options...
EL PAALO Posted November 5, 2007 Share Posted November 5, 2007 http://wheelspecs.com/OffsetCalculator.aspx the outer edge of the wheel will be at the same point as your previous 8.5 +46, but if you're using a wide tire, like a 245/35 18 then the tire will overhang the wheel somewhat vs the 8.5. Link to comment Share on other sites More sharing options...
