leggtnut Posted October 30, 2007 Share Posted October 30, 2007 So I am going to be replacing my Spec B Rev A with another set. This time I will do it myself. What should I be torquing all the bolts to? I have serched a bit and not found anything. any help? Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
isuace Posted October 30, 2007 Share Posted October 30, 2007 Check out the vacation pics to be sure, but I think that the lower bolts on the front and rear struts are like 112 ft.lbs and the top mounting nuts are like 24 ft.lbs. But like I said, check the vaca pics to be certain. Link to comment Share on other sites More sharing options...
leggtnut Posted October 30, 2007 Author Share Posted October 30, 2007 didn't know that they torque values would be there so didn't check. Thanks for the help. Will check them out Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
chenc544 Posted October 30, 2007 Share Posted October 30, 2007 Check out the vacation pics to be sure, but I think that the lower bolts on the front and rear struts are like 112 ft.lbs and the top mounting nuts are like 24 ft.lbs. But like I said, check the vaca pics to be certain. That's pretty much right except the front top 3 nuts are only about 14 ft-lbs. Just did my CO install over the weekend. The rear bottom bolts were PITA... Link to comment Share on other sites More sharing options...
isuace Posted October 30, 2007 Share Posted October 30, 2007 Nah, a floor jack and a 19mm wrench make easy work of them 'Course I've had mine off a couple times now :lol: Link to comment Share on other sites More sharing options...
