Sivs Posted February 16, 2007 Share Posted February 16, 2007 I finally made use of this write up last night and today. It made things slide along smoothly! Having the torque settings listed was also very much appreciated. In total it took me about 5 hours to do the install by myself. And the floor jack definitely came in handy when I had to untorque one of the lower rear strut bolts. All in all the car looks even better and body roll is gone for the most part. (Installed Ion springs instead of pinks.) Link to comment Share on other sites More sharing options...
RippinRoo Posted February 18, 2007 Share Posted February 18, 2007 Same here! Great instructions! I installed Swift springs... Thanks!! "I love the feel of wind in my face and boobies against my back." - BMW motorcycle rider Link to comment Share on other sites More sharing options...
praedet Posted March 19, 2007 Share Posted March 19, 2007 Just wanna say thanks for the write-up I used it to install my KW Variant 2s and DMS Camber Plates this past Friday. Getting that bottom bolt in the back torqued to spec TRULY sucks on jack stands Link to comment Share on other sites More sharing options...
vet Posted March 27, 2007 Share Posted March 27, 2007 Can the install be done without the special tools - 14mm crows foot and 17mm offset wrenches? Link to comment Share on other sites More sharing options...
Waxiboy Posted March 27, 2007 Share Posted March 27, 2007 I used: Breaker bar - lower strut bolt F&R 12mm socket - F tophat bolt 19mm offset+allen key - F upper strut nut 10mm socket - brake/ABS line bolts 19mm 6pt socket - lower strut bolt & nut F&R 14mm open/box - rear upper mount Torque wrench Jack & stands Link to comment Share on other sites More sharing options...
praedet Posted March 27, 2007 Share Posted March 27, 2007 Not really, you need the offset wrench or pass-through wrenches to pull it off... Link to comment Share on other sites More sharing options...
eVoMotion Posted March 30, 2007 Share Posted March 30, 2007 Great write up - will use as reminder on how to remove my Ksports and install my Megans' Link to comment Share on other sites More sharing options...
Ryandigi Posted January 20, 2009 Share Posted January 20, 2009 What should I torque the rear struts lower bolts to? I was able to get them off with just a 12 inch socket wrench with no need of my 26 inch breaker bar. I have a torque wrench, but from the sound of how hard it is to get it off my torque wrench might not even read that high!! Link to comment Share on other sites More sharing options...
SBT Posted January 20, 2009 Share Posted January 20, 2009 What should I torque the rear struts lower bolts to? I was able to get them off with just a 12 inch socket wrench with no need of my 26 inch breaker bar. I have a torque wrench, but from the sound of how hard it is to get it off my torque wrench might not even read that high!! From post # 1 Here are the torque specs: 1) Upper shock bolts - 22.4 ft-lb 2) Strut rod bolt - 41 ft-lb 3) Lower shock bolt - 118 ft-lb (ugh!) - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
erguby Posted September 6, 2009 Share Posted September 6, 2009 vice grips on a spark plug socket with hex down the middle.... Link to comment Share on other sites More sharing options...
ji79scoutii Posted March 22, 2010 Share Posted March 22, 2010 A word of caution if you are replacing the front upper strut mounts, neither the Moog K9559 nor the Monroe 902024 fit. The bolt pattern is about 1cm too small in each direction. These are listed as fits for 2005 Outback XTs on http://www.autopartswarehouse.com and http://www.amazon.com. The KYB SM5214 rear upper mounts do fit. The KYB SB101 rear boot kit and the KYB SB103 front boot kit both fit but are a little different than the stock boots. Link to comment Share on other sites More sharing options...
Duffman Posted June 28, 2010 Share Posted June 28, 2010 Thank u so much for this write-up. I used it as a guide to swap in a stock LGT suspension into my OBXT. My mini write-up Link to comment Share on other sites More sharing options...
specialB Posted December 1, 2011 Share Posted December 1, 2011 +1 for the awesome writeup, I will be putting this to use next weekend with my swift spring swap next weekend! Link to comment Share on other sites More sharing options...
ej25_TS Posted April 6, 2012 Share Posted April 6, 2012 subscribed Link to comment Share on other sites More sharing options...
SwaggerWagon05 Posted April 12, 2012 Share Posted April 12, 2012 Do you have saggy butt spacers in I didn't see that in there? Link to comment Share on other sites More sharing options...
