rs6er Posted October 10, 2007 Share Posted October 10, 2007 Every time I get in my car, my radio presets have disappeared. The only electrical mods I have done are the access-the-NAV-while-moving mod and disabling the seat belt warning. Any ideas what's causing this? Link to comment Share on other sites More sharing options...
SpawnGT Posted October 11, 2007 Share Posted October 11, 2007 ur constant power wire isnt conneted and this is a bad thing, id be watchful with the nav-while moving mod was done right, if im not mistaken that was a yellow wire, right? and the constant power wire is yellow as well, id go back and make sure the right one was cut. Link to comment Share on other sites More sharing options...
rs6er Posted October 11, 2007 Author Share Posted October 11, 2007 This may be related. Are the accessory power plug and lighter supposed to be hot with the ignition key out? Link to comment Share on other sites More sharing options...
SpawnGT Posted October 11, 2007 Share Posted October 11, 2007 lighter supposed to be hot with the ignition key out? um....do you mean like the lighter has been pressed in? becuase nothing should be hot. at most the front of the radio/ac should be slightly warmer from itself Link to comment Share on other sites More sharing options...
LGT Dave Posted October 11, 2007 Share Posted October 11, 2007 I think he means "hot" as in still getting power. I don't think the lighter and power plug are still powered with the ignition off. Link to comment Share on other sites More sharing options...
rs6er Posted October 11, 2007 Author Share Posted October 11, 2007 ^Couldn't have said it better. Link to comment Share on other sites More sharing options...
SpawnGT Posted October 11, 2007 Share Posted October 11, 2007 lighter isnt supposed to be on Link to comment Share on other sites More sharing options...
