CapnJack Posted October 3, 2007 Share Posted October 3, 2007 Are the door panels on the 07 LGT removed the same way as the 05 LGT? I see many write-ups on the 05, but none on the 07. It almost looks like the 07 has three different panels?? Thanks! Link to comment Share on other sites More sharing options...
str8dwn Posted October 3, 2007 Share Posted October 3, 2007 Nah, they are exactly the same as 05. The 3 panels you see are not separate in reality. Once you pop the handle off (a real pain), it's 3 screws and a pop-panel tool to take it off. Very simple actually. While you're in there, I highly recommend multiple layers of dampening material. One on the inside of the outer door skin, and two on the inner. I also made custom plexi pieces for the bottom large hole and silconed it in, much like Manville did on his. It is noticeably quieter from road noise, and adds a nice boost to midbass. Link to comment Share on other sites More sharing options...
