The Murdocta Posted September 27, 2007 Share Posted September 27, 2007 Anyone happen to know the ideal size of the bolt i need to hook up my stock downpipe to the Megan Racing Midpipe? I know some of you made the stock DP holes bigger for the supplied bolts to fit through but I'd rather just get a new set of bolts that hook up the stock DP and Megan MP. Right now im using the stock springy bolts and it leaks.... = Bad Heres the picture... Had to use cardomain cuz nothing else was working http://memimage.cardomain.net/member_images/8/web/2684000-2684999/2684781_14_full.jpg Will it Blend? That is the question! Link to comment Share on other sites More sharing options...
DoubleM Posted September 27, 2007 Share Posted September 27, 2007 I dunno, but I'm interested to know as well. What size spring bolts would stop the leaking? Link to comment Share on other sites More sharing options...
Boostjunkie Posted September 27, 2007 Share Posted September 27, 2007 I think I used M8-30mm flange bolts and matching flange nuts on the last stock DP car I installed a CBE on. I got them at OSH. You don't need to get metric hardware, I just like not having to swap to SAE tools to get at a couple fasteners, when everything else on the car is metric. Link to comment Share on other sites More sharing options...
The Murdocta Posted September 27, 2007 Author Share Posted September 27, 2007 K thanks, metric or SAE it doesn't really matter to me but i guess its better to keep it consistent. Will it Blend? That is the question! Link to comment Share on other sites More sharing options...
The Murdocta Posted September 27, 2007 Author Share Posted September 27, 2007 I dunno, but I'm interested to know as well. What size spring bolts would stop the leaking? Im actually convinced that the springbolts are tight enough, but I need some silicone sealer to stop the leaking because of the rust around the stock flange. But If im going to redo it all I might as well get the right bolts. Will it Blend? That is the question! Link to comment Share on other sites More sharing options...
Boostjunkie Posted September 27, 2007 Share Posted September 27, 2007 Im actually convinced that the springbolts are tight enough, but I need some silicone sealer to stop the leaking because of the rust around the stock flange. But If im going to redo it all I might as well get the right bolts. For the silicone sealant, just swing by your local autoparts store and pick up some Permatex Ultra Copper Silicone RTV. Just a couple of bucks and it does the job best. Link to comment Share on other sites More sharing options...
