The Don Posted September 26, 2007 Share Posted September 26, 2007 225x40x18 on 18x7.5 rims? i have 35f 33r right now? Link to comment Share on other sites More sharing options...
andrew.anderson Posted September 26, 2007 Share Posted September 26, 2007 That is fine. A little high maybe. It depends on your driving, the load you are carrying and what handling characteristics you want. Link to comment Share on other sites More sharing options...
fweasel Posted September 26, 2007 Share Posted September 26, 2007 I run a little more than that on the same size tires, about 37/35. Seems to work at the trak as well. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
wukindada Posted September 26, 2007 Share Posted September 26, 2007 I'd keep that size right around 39f/37r Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
DrGrip Posted September 26, 2007 Share Posted September 26, 2007 What tires? Link to comment Share on other sites More sharing options...
SpecBee Posted September 26, 2007 Share Posted September 26, 2007 What was the temp outside when you measured psi? Were the tires warm? Link to comment Share on other sites More sharing options...
The Don Posted September 26, 2007 Author Share Posted September 26, 2007 eagle f1 gs d3 it was about 85F outside and the tires were not warm Link to comment Share on other sites More sharing options...
fweasel Posted September 26, 2007 Share Posted September 26, 2007 eagle f1 gs d3 it was about 85F outside and the tires were not warm Same tires that I run on 18x8 wheels. Even with springs and Tokicos, I'm happy with the ride at 37/35 ignore him, he'll go away. Link to comment Share on other sites More sharing options...
DrGrip Posted September 27, 2007 Share Posted September 27, 2007 eagle f1 gs d3 it was about 85F outside and the tires were not warm Oh, if it were we i'd probably turn them up to make up for the soft sidewalls.. Link to comment Share on other sites More sharing options...
andrew.anderson Posted September 27, 2007 Share Posted September 27, 2007 Am I crazy...isn't the recommended PSI printed on the side of the tires. Link to comment Share on other sites More sharing options...
The Don Posted September 27, 2007 Author Share Posted September 27, 2007 I think its the max thats on the tire...but inside my driver door subie has something it says fill tires to 33f 35r...im guessing for stock Link to comment Share on other sites More sharing options...
wukindada Posted September 27, 2007 Share Posted September 27, 2007 & that max is when the tires are cold. My guess is that your tire has a 44-45psi max rating....If it were me, I'd run 39/37 Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
