jvento Posted October 24, 2007 Share Posted October 24, 2007 like any 1/4mile car you have to disconnect the front sway bar like on my mustang, I have on need for a front swaybar for the track and on our subi it a 60/40 split or I can be wrong. and if you have an adjustable shocks the rear on soft an the front my vary. Link to comment Share on other sites More sharing options...
RangerMan Posted November 6, 2007 Share Posted November 6, 2007 For an AWD car you want it to be as stiff as possible. You are trying to keep all of your drive wheels in contact with the ground. For the Mustang you disconnect the front sway and keep the rears soft so you get maximum weight transfer. You do that with an AWD and you will just be hurting your 1/4 times. To mschmidt, Go Highlanders! Link to comment Share on other sites More sharing options...
ScoopMan Posted November 6, 2007 Share Posted November 6, 2007 wtf do sways have to do with front/rear weight transfer? They are only active for side-to-side weight transfer amigo. Take em off to reduce weight, that's about it. Link to comment Share on other sites More sharing options...
RangerMan Posted November 6, 2007 Share Posted November 6, 2007 Right. 20lbs. off the front makes it that much easier to shift weight to the back. Again only applicable for drag racing with a RWD car... Link to comment Share on other sites More sharing options...
ScoopMan Posted November 6, 2007 Share Posted November 6, 2007 Well I guess you would leave the back sway on the rwd car to reduce effects of driveline torque as well. But this is side-to-side weight transfer again... Link to comment Share on other sites More sharing options...
