NovaWolverine Posted September 20, 2007 Share Posted September 20, 2007 My bad, I was referring to if you just had a DP and intermediate y-pipes w/ stock mufflers. How much power are you missing out on compared to most exhaust set ups? Link to comment Share on other sites More sharing options...
wukindada Posted September 20, 2007 Share Posted September 20, 2007 With the stock turbo???? negligible....2-3hp Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
NovaWolverine Posted September 20, 2007 Share Posted September 20, 2007 i will probably have to get an exhaust because all i want is 300/300 or so i say now. i hate the drone though. i would need to upgrade the ic and turbo, but the turbo would still be small. Link to comment Share on other sites More sharing options...
wukindada Posted September 20, 2007 Share Posted September 20, 2007 If you have any suby bucks pick up the 08 SPT catback. If not.... the SP2 with a resonator installed will have no drone;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
loopless Posted September 20, 2007 Share Posted September 20, 2007 Few questions from cat-back newbie... I have a crucial DP and high flow catted mid-pipe that currently connects up at the doughnut to the stock exhaust. 1) can I replace just the Y-pipe? 2) can I buy just a Y-pipe? I notice Cobb sells Y-pipe+mid-pipe together. 3) where is the resonator? Is it in the Y-pipe? 4) Does replacing the Y-pipe=drone because of 2) 5) Do wagons have a different Y-pipe to sedans? Link to comment Share on other sites More sharing options...
Chrisman Posted September 21, 2007 Author Share Posted September 21, 2007 I haven't seen any ads for just a Y-pipe. They usually come with the midpipe. Cobb and AVO sell intermediate and y-pipe combo packages. I noticed that Crucial sells a "shorty" DP and a midpipe with HFC. Does the stock midpipe have a cat (third cat)? And what does "shorty" mean when refering to a DP? Thank in advance. Link to comment Share on other sites More sharing options...
loopless Posted September 21, 2007 Share Posted September 21, 2007 The stock mid-pipe and the Crucial mid-pipe both have a cat. Basically the stock exhaust has a 'shorty DP' ( with cat) followed by a mid-pipe with cat. Crucial sell a shorty DP without cat, and a mid-pipe with high flow cat. Other vendors sell a one piece 'full length' DP that replaces those two pieces. Everyone has to put a cat of some type in the mid-pipe area or your exhaust will be stinky and polluting. Link to comment Share on other sites More sharing options...
Chrisman Posted September 21, 2007 Author Share Posted September 21, 2007 The stock mid-pipe and the Crucial mid-pipe both have a cat. Basically the stock exhaust has a 'shorty DP' ( with cat) followed by a mid-pipe with cat. Crucial sell a shorty DP without cat, and a mid-pipe with high flow cat. Other vendors sell a one piece 'full length' DP that replaces those two pieces. Everyone has to put a cat of some type in the mid-pipe area or your exhaust will be stinky and polluting. Thanks for your response. That clears things up for me. It has finally clicked that the stock setup has Front, mid, intermediate, and y pipes (please correct me if I'm wrong). Link to comment Share on other sites More sharing options...
SBT Posted October 18, 2008 Share Posted October 18, 2008 Like DF, I'm piggy-backing on this thread. Are there any aftermarket resonated Mid/Y-pipe combos (regardless of I.D.) that bolt up to the stocker's DP donut flange. It appears that Megan "may", but then it doesn't appear that they also don't work with stock or other stock fitment cans. All of the rest seem to have a flat-flange setup. I'm trying to figure out what available Mid/Y-Pipe setup to connect my Cobb DP to my Prodrive Cans and keep the stock donut gasketing and spring-bolts. The Prodrive inlets are 2" IIRC so would like something that also increases the I.D. of the Y-pipe connector-side too. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Guest Posted October 20, 2008 Share Posted October 20, 2008 Get Perrin Y-pipe, best one out there. It does not mate to the donut (you loose it) but it has flex section. Future proof when you get 3 inch downpipe. It mates to stock dp without donut fine, although I used Remflex 3" inch gasket that I am sure helped with the seal. Link to comment Share on other sites More sharing options...
SBT Posted October 20, 2008 Share Posted October 20, 2008 I don't have plans to strap on a high output turbo so I'll be staying with the COBB HFC DP and want something that will mate, post-DP with the donut connector. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SBT Posted October 20, 2008 Share Posted October 20, 2008 Get Perrin Y-pipe, best one out there. It does not mate to the donut (you loose it) but it has flex section. Future proof when you get 3 inch downpipe. It mates to stock dp without donut fine, although I used Remflex 3" inch gasket that I am sure helped with the seal. More info on the Remflex 3" gasket? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Guest Posted October 20, 2008 Share Posted October 20, 2008 Just go to remflex website, it's there Link to comment Share on other sites More sharing options...
