arty288 Posted September 10, 2007 Share Posted September 10, 2007 Hi, I have a '97 Legacy GT. First Turbo kicks in properly at 3000rpm. After 5000 the revs crawl thier way through to 6500-7000. No idea why 2nd one does nothing!!!! Anyone encountered this problem before and how was it resolved? Apparently this is a common issue? Any advice would be greatly appreciated. Link to comment Share on other sites More sharing options...
apexjapan Posted September 10, 2007 Share Posted September 10, 2007 It would probably be helpful to list where you are at - this forum is mainly American, and the twin turbo Legacy GT models were not sold in America. At least in Japan, it's not a common issue. Is there any noises coming from the secondary turbo? Are there any hoses that are loose? Has there been any modifications to the car? Cheers, Paul Hansen http://www.avoturboworld.com Link to comment Share on other sites More sharing options...
arty288 Posted September 10, 2007 Author Share Posted September 10, 2007 Hi Paul.. I'm from UK but living in Kenya.. Most vehicles here are actually imported JDM models, as is mine.. Modifications to suspenion (spacers and STi shocks - ground clearance is a premium given road conditions), then also an after-market exhaust.. although the only engine modification is a Blow Off Valve.. I have been told to check if the hoses are loose and I will have that done.. As for noise from 2nd Turbo, do you mean the same noise the first Turbo makes as it spools up? ( High pitched Whiiirrrrrr!!) either way the 2nd Turbo makes no noise - no whiiiir or any other sound... Any clues? Thanks, Arty Link to comment Share on other sites More sharing options...
arty288 Posted September 10, 2007 Author Share Posted September 10, 2007 Car is BG5 model Engine EJ20 2 (stage turbo) Link to comment Share on other sites More sharing options...
