bman Posted September 4, 2007 Share Posted September 4, 2007 I've been looking on HID Planet and I wanted to know what the retro-ers here were doing about this? Since there's no sealed place to mount the ballasts, where are people putting their ballasts? Especially where I am (in the N.E.) there's snow, salt, and rain to worry about. I saw that I can "pot" the ballasts but, that seems like an extreme. Thanks Link to comment Share on other sites More sharing options...
mr_luv Posted September 4, 2007 Share Posted September 4, 2007 ziplock it and e-tape it up and hang mount under the headlight housing with 3M double sided tape thats where mines were last winter ALLL OF LAST WINTER. Here in MD Mr.350 Link to comment Share on other sites More sharing options...
bman Posted September 4, 2007 Author Share Posted September 4, 2007 >> ziplock it and e-tape what about the heat from the ballasts? wouldn't it melt the plastic? also, which ballasts are you using? I'm considering denso slims. Link to comment Share on other sites More sharing options...
mr_luv Posted September 4, 2007 Share Posted September 4, 2007 Yea those are the ones I used, Yes they get hot but mines didnt melt the plastic bag I didnt run into any troubles. Just checked it when I had the bumper off and changed it every season. >> ziplock it and e-tape what about the heat from the ballasts? wouldn't it melt the plastic? also, which ballasts are you using? I'm considering denso slims. Mr.350 Link to comment Share on other sites More sharing options...
laz Posted September 4, 2007 Share Posted September 4, 2007 My driver's side is on top of the windshield washer fluid reservoir and the passenger is under the headlight. Both are held in place with the double sided foam tape. Going on strong for 2 years now. X --- Link to comment Share on other sites More sharing options...
lookslikeanevo Posted September 4, 2007 Share Posted September 4, 2007 driverside fenderwell passenger side horns or under the headlights Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
bman Posted September 5, 2007 Author Share Posted September 5, 2007 laz, lookslikeanevo, what did you guys do (if anything) to protect the ballasts from water/rain/snow? Link to comment Share on other sites More sharing options...
laz Posted September 5, 2007 Share Posted September 5, 2007 laz, lookslikeanevo, what did you guys do (if anything) to protect the ballasts from water/rain/snow? I did not do anything. I check them once in a while, and they seem perfect. X --- Link to comment Share on other sites More sharing options...
lookslikeanevo Posted September 5, 2007 Share Posted September 5, 2007 I did not do anything. I check them once in a while, and they seem perfect. X if you place it in a decent area it really wont get affected, i also did nothing to protect em Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
mr_luv Posted September 5, 2007 Share Posted September 5, 2007 Ziplockit Mr.350 Link to comment Share on other sites More sharing options...
kjiz Posted September 5, 2007 Share Posted September 5, 2007 If you got densos go to Toyota and buy the oem ballast covers from them. I think it was like $20ish. Mount wherever. Link to comment Share on other sites More sharing options...
bman Posted September 6, 2007 Author Share Posted September 6, 2007 kjiz, I thought the covers were only the bottom half? The top half being part of the headlight assembly w/ a hole for the wires to reach the bulb? The pics I've seen of the LGT ballast mount w/ cover is under the headlight assembly and there's a gap where stuff (water, salt, dirt) can get in and corrode the ballast. I'm thinking long term what that's gonna do to the ballast. Link to comment Share on other sites More sharing options...
CarbonCrew Posted September 7, 2007 Share Posted September 7, 2007 Here's what I did with mine. Self explanatory... http://aycu16.webshots.com/image/19255/2003012030230260760_rs.jpg Link to comment Share on other sites More sharing options...
ErichCS Posted November 22, 2007 Share Posted November 22, 2007 Are those the toyota ballast covers you have pictured there? I just got my ballasts today with bulbs and i am going to be starting this project very soon, i would like to have all the right parts before i begin. Link to comment Share on other sites More sharing options...
VXCL Posted November 25, 2007 Share Posted November 25, 2007 My driver's side is on top of the windshield washer fluid reservoir and the passenger is under the headlight. Both are held in place with the double sided foam tape. Going on strong for 2 years now. X same here, driver side is velcro'd to top of washer fluid bottle and passenger side is ziptied to chassis under headlamp. A couple layers of 3m professional duct tape will keep them safe for the entire time you own the car. just make sure if you dont have sealed ballasts like the older hellas or kioto (lexus toyota) that you seal up where the wires enter really well. water always finds a way in. i had to use some silcone sealant since my ballasts are far from being a sealed type MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
Bbc84 Posted November 25, 2007 Share Posted November 25, 2007 drivers side lowbeam i bent the bracket to HID ballast and threaded it through the battery tie down bolt. drivers side fog I 3M double side taped it to the windshield washer reservoir. The Passnger side lowbeam and fogs a Zip tied both balast together, then ziptie the whole thing to the bottom of the intake (I removed the resonator) so theres a popit hole on the intake pipe from removing the resonator. Ill probably need to change that up because Im sure eventually ill wear a hole into the air intake. Link to comment Share on other sites More sharing options...
CarbonCrew Posted November 26, 2007 Share Posted November 26, 2007 Are those the toyota ballast covers you have pictured there? I just got my ballasts today with bulbs and i am going to be starting this project very soon, i would like to have all the right parts before i begin. Yes those are RX330 ballast covers. Link to comment Share on other sites More sharing options...
mr_luv Posted November 26, 2007 Share Posted November 26, 2007 Where did you get yours? Gotta part # Yes those are RX330 ballast covers. Mr.350 Link to comment Share on other sites More sharing options...
feelander Posted November 26, 2007 Share Posted November 26, 2007 Where did you get yours? Gotta part # same ones also come on celica. can get them from toyota see part numbers here Link to comment Share on other sites More sharing options...
mr_luv Posted November 26, 2007 Share Posted November 26, 2007 Thanks I wonder what kinda projectors do the celica use with OEM hids. same ones also come on celica. can get them from toyota see part numbers here Mr.350 Link to comment Share on other sites More sharing options...
CarbonCrew Posted November 26, 2007 Share Posted November 26, 2007 Where did you get yours? Gotta part # I got mine when I purchased two complete RX330 headlights. I think the Celica projectors are made by Stanley, just like the STI, RX8, and RX 330, as well as some others. Link to comment Share on other sites More sharing options...
PhilT Posted November 26, 2007 Share Posted November 26, 2007 Under the passenger seat. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
ErichCS Posted November 30, 2007 Share Posted November 30, 2007 Thanks for the tip on the Toyota part number...i just ordered two of them for $7.?? each. Link to comment Share on other sites More sharing options...
gianspi Posted November 30, 2007 Share Posted November 30, 2007 Gorilla glue? enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
gianspi Posted November 30, 2007 Share Posted November 30, 2007 so that is a no for gorilla glue? enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
