Alpinestars96 Posted August 30, 2007 Share Posted August 30, 2007 I did a search and found some helpful info. But, I want to let people know what I am noticing. Today it was about 96 degrees, and I turned my car on and pushed auto and turned the knobs down to 65 before i punched out for work. When I came back I noticed it wasn't blowing very cold sitting there, but when i started driving it went colder then at the stop light it went warm again. Then I started it tonight the temp was around 86 and the ac was fine. Anyone experience this? Thanks. Link to comment Share on other sites More sharing options...
meier motor sports Posted August 30, 2007 Share Posted August 30, 2007 the condenser in the front of the car works with air flow. when the car is not moving and the air is not flowing you do not get adequate cooling. thats why Link to comment Share on other sites More sharing options...
one69chev Posted August 30, 2007 Share Posted August 30, 2007 ^^^^what he said and also subies don't have the best HVAC systems.... Link to comment Share on other sites More sharing options...
LongHiway Posted August 30, 2007 Share Posted August 30, 2007 Here's my experience and $0.02. "Auto-Climate" and A/C don't work well together. Use the A/C in manual mode. It's also tempting to set the fan speed on "max" when trying to cool the car down on a real hot / humid day. That works but only gets you about 10 degrees cooler than outside air. The problem (I think) is too much air flow across the evap coil. Set the fan speed lower (3 - 4), and the air temp gest measurably colder but, certainly less volume. Within a couple of minutes you should see a diff. I'll admit, 96 is a strain on the Subie A/C. Link to comment Share on other sites More sharing options...
wukindada Posted August 30, 2007 Share Posted August 30, 2007 I have never had issues with mine.... Always keep the temp on 68* & the fan on the second notch even with the extra room of the wagon I'm always comfortable even with temps over 90 6mo out of the year. Are your windows tinted?? It was 96* here yesterday with 78% humidity & my daughter asked me to turn the air up bc she was cold.... Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
Scotty Posted August 30, 2007 Share Posted August 30, 2007 Only 96 and you are whining. Got in my car after work yesterday, it was 109. Link to comment Share on other sites More sharing options...
wukindada Posted August 30, 2007 Share Posted August 30, 2007 Waiting @ a light yesterday @ 6:30pm my temp readout was still saying 96......... Heat index yesterday & today is 106 Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
