leggtnut Posted August 20, 2007 Share Posted August 20, 2007 So picked up a Outback Front bumper under guard. I installed it today. Looks awsome. Here is my write up: First you need the following tools: Philips Screw driver, Flat Head Screw Driver, Drill, 3/4" drill bit (or metric equilivant), and a little elbow greese To remove the front bumper, follow the directions here (I did): http://legacygt.com/forums/showthread.php?t=3737 Now you need to test fit the bumper guard to find the locations to drill. I was a little hesitant on this part, but it is under the car and you will never see it unless you get under there. I used a pen to outline the holes. From there I drilled the holes. See picture 1 I then installed the guard with the pop-it's. Now for the hard part. The upper mounting points. I found the easiest thing to do is to mount the mounting plates to the guard and then clip them against the bumper, there is a ridge for it to hold against to. There must be 2 holes on each side of the bumper, which the legacy doesn't. See Picture 2 From there re-intsll the bumper and grill and you are set. See the rest of the pictures. Just one note: The bumpers lower bar are slightly different as well. There is about a 1/8" gap both vertical and horzontal. So it isn't a 100% fit, but close enough and it isn't notisable. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
el5y Posted August 21, 2007 Share Posted August 21, 2007 nice!, It doesn't quite seem to fit exactly but looks pretty good. Link to comment Share on other sites More sharing options...
ArcTec34 Posted August 24, 2007 Share Posted August 24, 2007 interesting.. glad you like it. ill keep my front lip Link to comment Share on other sites More sharing options...
