panamajack Posted December 1, 2004 Share Posted December 1, 2004 I know alot of us are looking for a tunner that will work with either the Accessport or the XEDE. Being on So. California are their tunners here that will tune them for you or do have to drive very far to get it done. Sorry for being a total n00b, but I have to ask. Link to comment Share on other sites More sharing options...
SUBY3 Posted December 1, 2004 Share Posted December 1, 2004 XS engineering in Huntington beach Link to comment Share on other sites More sharing options...
panamajack Posted December 1, 2004 Author Share Posted December 1, 2004 Do they tune with both? If I want the Vinshu tune do I have to go to him, or can XS do the same thing using his maps? Link to comment Share on other sites More sharing options...
Rommel Posted December 3, 2004 Share Posted December 3, 2004 There are a couple of places in the L.A. area like Harman Motive and Easy Street. You could go to NASIOC.com and check the SCIC forums for more tuners in the area. Link to comment Share on other sites More sharing options...
Boostjunkie Posted December 3, 2004 Share Posted December 3, 2004 There is no DIY tuning with the Accessport. Cobb makes the Accessport and will offer a variety of preset off-the-shelf maps for it, but there is no user tunability until they release the AccessTuner... which should have been out a while ago, but seems to be on indefinate hold right now. If you want user tunability you'll want the XEDE or UTEC. If you want a tuner to do the work for you, and then have it as a set and forget proposition, then Ecutek is the way to go. While I have no first hand experience with them, both Harman Motive seems to have a good rep. I-Speed recently moved to SoCal, you they become a good option as well. Heck, a the Bay Area isn't that far a drive up to Vishnu. Lots of options. Link to comment Share on other sites More sharing options...
panamajack Posted December 6, 2004 Author Share Posted December 6, 2004 Boostjunkie have you heard anymore from shiv regarding the legacy XEDE? I know he tuned an auto for 100+ pounds of torque using just a reflash. I would defenitley take a trip up north to let him work some magic on my car. Link to comment Share on other sites More sharing options...
Rommel Posted December 6, 2004 Share Posted December 6, 2004 Panamajack - try Harman Motive they are local, if you just want a reflash. I think Harman Motive charges around $1k for a reflash with dyno. Link to comment Share on other sites More sharing options...
Boostjunkie Posted December 6, 2004 Share Posted December 6, 2004 [quote name='panamajack']Boostjunkie have you heard anymore from shiv regarding the legacy XEDE? I know he tuned an auto for 100+ pounds of torque using just a reflash. I would defenitley take a trip up north to let him work some magic on my car.[/QUOTE] I think Vishnu can also use the XEDE on the LGT, but there haven't been any posted numbers for that setup. The 100 ft./lbs. gain is a little misleading, as this was the largest delta between stock and reflashed. It occured at low rpms. The peak gain was closer to 45-50 ft./lbs. Still impressive stuff nonetheless, for nothing more than an Ecutek reflash. Link to comment Share on other sites More sharing options...
Rommel Posted December 17, 2004 Share Posted December 17, 2004 Panamajack - just talked to Dan at Harman Motive EcuTek is $850 with dyno time. He will dyno the car stock then do the reflash and tune then dyno again to see how much whp you gained after the tune. Link to comment Share on other sites More sharing options...
Deer Killer Posted December 17, 2004 Share Posted December 17, 2004 [quote name='Boostjunkie']I think Vishnu can also use the XEDE on the LGT, but there haven't been any posted numbers for that setup. The 100 ft./lbs. gain is a little misleading, as this was the largest delta between stock and reflashed. It occured at low rpms. The peak gain was closer to 45-50 ft./lbs. Still impressive stuff nonetheless, for nothing more than an Ecutek reflash.[/QUOTE] Yeah looks like that 100ft/lbs was all torque convertor at that low rpm. Misleading. Link to comment Share on other sites More sharing options...
panamajack Posted December 17, 2004 Author Share Posted December 17, 2004 Yeah I want to get tunned , but I am going to wait until I get my suspension finished. By that time there will be some choices on downpipes and cat-backs. The dual tip STI does look tempting though. Link to comment Share on other sites More sharing options...
Rommel Posted December 17, 2004 Share Posted December 17, 2004 [quote name='panamajack']Yeah I want to get tunned , but I am going to wait until I get my suspension finished. By that time there will be some choices on downpipes and cat-backs. The dual tip STI does look tempting though.[/QUOTE] And it also sounds good, not too loud, with the EcuTek reflash you will get around 210 whp. My wagon will be a total sleeper. Link to comment Share on other sites More sharing options...
