Andyjo Posted August 14, 2007 Share Posted August 14, 2007 So i installed the coilovers a while ago, have at least 5000 miles on them, and a while ago i started to notice that on slow speed sharp turns (parking lots etc...) i get a 'clunk' out of the front end. I'm guessing it's the swaybar, or the links, any ideas? i had a similar issue with my lifted impreza, the swaybar was just over stressed because of the lift, think the same thing could be happening because the OBXT is ~ 2" lower? Link to comment Share on other sites More sharing options...
Boostjunkie Posted August 14, 2007 Share Posted August 14, 2007 So i installed the coilovers a while ago, have at least 5000 miles on them, and a while ago i started to notice that on slow speed sharp turns (parking lots etc...) i get a 'clunk' out of the front end. I'm guessing it's the swaybar, or the links, any ideas? i had a similar issue with my lifted impreza, the swaybar was just over stressed because of the lift, think the same thing could be happening because the OBXT is ~ 2" lower? Check the endlinks for play. Also check that the top nut on the coilovers is tight and that the lock rings are also tight. Those 3 things will account for at least 95% of clunks. Link to comment Share on other sites More sharing options...
Andyjo Posted August 14, 2007 Author Share Posted August 14, 2007 ahh ha! one of the castle nuts was wayyy loose. went around and checked all of them, but it was only the front pass side. Link to comment Share on other sites More sharing options...
Boostjunkie Posted August 15, 2007 Share Posted August 15, 2007 ahh ha! one of the castle nuts was wayyy loose. went around and checked all of them, but it was only the front pass side. Told ya! Link to comment Share on other sites More sharing options...
Andyjo Posted August 27, 2007 Author Share Posted August 27, 2007 It's still there! deff. coming from the swaybar though... i'll update this when i figure out how to fix it.. maybe a little grease on the bushings... Link to comment Share on other sites More sharing options...
lawl Posted August 27, 2007 Share Posted August 27, 2007 my sways clunk all the time in the miata. part of the reason why i dont think im going to get sways on the legacy. dont know what causes it. but when i adjusted the rear sway to be tighter (they're adjustables, 2 sets of bolt holes), the noise went away. dont know what that means. but i've put it back to normal/understeer setting and it clunks again car for sale. PM me! Link to comment Share on other sites More sharing options...
