Silver_05_GTX Posted August 11, 2007 Share Posted August 11, 2007 I live in NC and use M1 5w-30 in my 05 GT... In the owners manual it has a chart indicating that the upper ambient range for 5w-30 oil is 100 deg F. I recently saw a post on bitog which had analysis that M1 5w-30 is thicker at temperature than 10w-30 is, despite the fact that the chart in the Subaru owners manual shows that 10w-30 can be used in hotter climates than 5w-30. I was intrigued that the analysis on bitog showed the 5w-30 thicker at temp, I would have expected that anything Xw-30 would perform quite similar at temperature. In any case, It hasn't been below 100 deg here for over a week...should I be concerned? Link to comment Share on other sites More sharing options...
Beanboy Posted August 11, 2007 Share Posted August 11, 2007 Nope. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
the_3d_man Posted August 17, 2007 Share Posted August 17, 2007 Despite the fact that both oils are classified as 30 weight at operating temp, the 10W-30 should actually be slightly heavier than the 5W-30. The 5W-30 falls in the lower of the acceptable viscosity ranges to be called 30 weight, and the the 10W-30 falls in the upper part of the acceptable range to be called 30 weight. I think it is like this for Mobil One oils. I know this is true for some others because I have seen the raw cut data from a refinery for similar oils (data that shows actual viscosities over temp ranges). I have been running 10W-30 for the summer but will go back to 5W-30 (or if I can find it 0W-30GC ) on my next oil change. Link to comment Share on other sites More sharing options...
Silver_05_GTX Posted August 17, 2007 Author Share Posted August 17, 2007 Despite the fact that both oils are classified as 30 weight at operating temp, the 10W-30 should actually be slightly heavier than the 5W-30. The 5W-30 falls in the lower of the acceptable viscosity ranges to be called 30 weight, and the the 10W-30 falls in the upper part of the acceptable range to be called 30 weight. I think it is like this for Mobil One oils. I know this is true for some others because I have seen the raw cut data from a refinery for similar oils (data that shows actual viscosities over temp ranges). I have been running 10W-30 for the summer but will go back to 5W-30 (or if I can find it 0W-30GC ) on my next oil change. I will try to find the post on bitog that indicates otherwise... Another anecdote...It's well established that GC 0W-30 is actually one of the heaviest 30 wt oils at temperature... Link to comment Share on other sites More sharing options...
