kevinh Posted August 2, 2007 Share Posted August 2, 2007 The 2006-2007 WRX TR editions come equiped with...front and rear, red, 4-piston calipers. Does anyone know if these calipers are a direct bolt-on for us Legacy owners? They would be a great improvement over stock 2-piston calipers, and less cost over replacing calipers, rotors, lines, etc., with a brake kit. Dave at MSPT wasn't sure...and hasn't had time to look up part numbers. But agrees, this would be a huge upgrade. KevinH Link to comment Share on other sites More sharing options...
praedet Posted August 2, 2007 Share Posted August 2, 2007 The front is a direct bolt-on. The rear takes a little work... Do a search to see if they are worth-while Link to comment Share on other sites More sharing options...
jim1969 Posted August 2, 2007 Share Posted August 2, 2007 are they worth it for the price and performance they give? Link to comment Share on other sites More sharing options...
praedet Posted August 2, 2007 Share Posted August 2, 2007 SEARCH, it is your friend Link to comment Share on other sites More sharing options...
biz77 Posted August 4, 2007 Share Posted August 4, 2007 Anyone interested in this swap, I'm throwing you a bone: This is a DOWNGRADE in braking capability over the standard LGT(front) brakes!!! Link to comment Share on other sites More sharing options...
kevinh Posted August 4, 2007 Author Share Posted August 4, 2007 I found out the rotors are smaller on the WRX TR...but that's not the swap. If you read carefully, I'm interested in swapping the the calipers. The WRX calipers are 4-piston compared to our 2-piston. How is that a downgrade? KevinH Link to comment Share on other sites More sharing options...
PGT Posted August 4, 2007 Share Posted August 4, 2007 because the designs are not the same. small 4 piston fixed !> large 2 piston floating design. Also...how do you propose to put a larger rotor in a caliper designed for a smaller one? Link to comment Share on other sites More sharing options...
RobE Posted August 4, 2007 Share Posted August 4, 2007 because the designs are not the same. small 4 piston fixed !> large 2 piston floating design. http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
praedet Posted August 5, 2007 Share Posted August 5, 2007 I saw a Acura RSX the other day and it had shiny silver calipers. Can I use them? They would be an upgrade because they are shiny and silver... Link to comment Share on other sites More sharing options...
sexylegacy Posted August 5, 2007 Share Posted August 5, 2007 Your money is better spent on some Super-blue fluid and axxis ultimate pads, or some other high quality brake pad. The stock brakes on the LGT are absolutely fantastic. What other car HAS to come with 17" wheels stock just to clear the brakes? Link to comment Share on other sites More sharing options...
biz77 Posted August 5, 2007 Share Posted August 5, 2007 I found out the rotors are smaller on the WRX TR...but that's not the swap. If you read carefully, I'm interested in swapping the the calipers. The WRX calipers are 4-piston compared to our 2-piston. How is that a downgrade? Kevin, I know we've covered this before SOMEWHERE: http://www.legacygt.com/forums/showthread.php?t=65833&page=2 Link to comment Share on other sites More sharing options...
PGT Posted August 5, 2007 Share Posted August 5, 2007 I saw a Acura RSX the other day and it had shiny silver calipers. Can I use them? They would be an upgrade because they are shiny and silver... they would look great bolted to your mirrors....air brakes! Link to comment Share on other sites More sharing options...
praedet Posted August 6, 2007 Share Posted August 6, 2007 ^^^ Link to comment Share on other sites More sharing options...
lawl Posted August 6, 2007 Share Posted August 6, 2007 people with wrxs ask to trade UP to our setup. my friend wants mine if i go brembo. car for sale. PM me! Link to comment Share on other sites More sharing options...
zildjiank Posted August 6, 2007 Share Posted August 6, 2007 Wow, I don't know how hard it is to understand this concept... It's DEFINITELY a downgrade because of piston sizing. When I talked to a guy at stoptech about their WRX kit and whether it would be a good thing to put on my leggy, even he told me that the WRX STOPTECH kit was designed specifically for that vehicle, and I would be downgrading if I did not specifically go with the one from Stoptech designed for the legacy. Oh, he even went so far as to say that the Brembo wrx-sti brakes weren't meant for the leggy either...and people are downgrading when going with that also, because the leggy's PISTON diameter is much larger than both the wrx and sti... Just my 2cent. Link to comment Share on other sites More sharing options...
praedet Posted August 6, 2007 Share Posted August 6, 2007 ^^^^Mostly true Link to comment Share on other sites More sharing options...
kevinh Posted August 6, 2007 Author Share Posted August 6, 2007 Wow, I don't know how hard it is to understand this concept... It's DEFINITELY a downgrade because of piston sizing. When I talked to a guy at stoptech about their WRX kit and whether it would be a good thing to put on my leggy, even he told me that the WRX STOPTECH kit was designed specifically for that vehicle, and I would be downgrading if I did not specifically go with the one from Stoptech designed for the legacy. Oh, he even went so far as to say that the Brembo wrx-sti brakes weren't meant for the leggy either...and people are downgrading when going with that also, because the leggy's PISTON diameter is much larger than both the wrx and sti... Just my 2cent. That makes a lot of sense, and I understand now what your saying. Thanks. KevinH Link to comment Share on other sites More sharing options...
zildjiank Posted August 6, 2007 Share Posted August 6, 2007 ^^^^Mostly true Coming from teh only member on here w/ the full Stoptech leggy setup Link to comment Share on other sites More sharing options...
praedet Posted August 7, 2007 Share Posted August 7, 2007 Link to comment Share on other sites More sharing options...
mattg Posted August 7, 2007 Share Posted August 7, 2007 That's pretty tough to believe considering the calipers are almost twice the size of the stockers, and the rotors are much larger. Jarrad @ PDX said he never would have sold his 332x32 Legacy specific kit if it performed as well as my WRX specific kit does. When I talked to a guy at stoptech about their WRX kit and whether it would be a good thing to put on my leggy, even he told me that the WRX STOPTECH kit was designed specifically for that vehicle, and I would be downgrading if I did not specifically go with the one from Stoptech designed for the legacy. Link to comment Share on other sites More sharing options...
zildjiank Posted August 7, 2007 Share Posted August 7, 2007 calipers are almost twice the size Yes, the CALIPERS are, but the pistons indeed are not... Link to comment Share on other sites More sharing options...
praedet Posted August 7, 2007 Share Posted August 7, 2007 But they are painted Link to comment Share on other sites More sharing options...
Wales Garage Posted August 8, 2007 Share Posted August 8, 2007 my next brake upgrade will consist of a parachute, an anchor, and a winch. Link to comment Share on other sites More sharing options...
