cookin Posted November 27, 2004 Share Posted November 27, 2004 I see that some people have installed amps in the LGT but there hasnt been much information posted on how it was done. How did you connect to the stock head unit? Im looking to install a crossover from the headunit and run 2 amps for the sub, component front, and coaxial rear. Has anyone done anything like this yet? Thx, Brandon. Link to comment Share on other sites More sharing options...
Cascade-LGT Posted November 27, 2004 Share Posted November 27, 2004 [size=1]The OEM head unit does not have pre-amp outputs so you are restricted to using a line output converter. I did this and am pretty satisfied with the resutls. There have been several threads which will yield instructions and pictures of how to install an amp. With that basic information you should be able do your install if you can accept the compromise of a LOC.[/size] By the way welcome to forum - good to have another NW person... Link to comment Share on other sites More sharing options...
GTLegs Posted November 28, 2004 Share Posted November 28, 2004 a cheap LOC worked fine for me after crossing it through my amp Link to comment Share on other sites More sharing options...
Rexmobbin Posted November 28, 2004 Share Posted November 28, 2004 i used an LOC located directly behind the headunit for my sub install. sounds great. Link to comment Share on other sites More sharing options...
cookin Posted November 28, 2004 Author Share Posted November 28, 2004 thanks everyone for the input. i'll give it a shot. Brandon Link to comment Share on other sites More sharing options...
cookin Posted November 28, 2004 Author Share Posted November 28, 2004 I'll try to do a narrative and get some pics while I'm doing the install. Link to comment Share on other sites More sharing options...
Cascade-LGT Posted November 29, 2004 Share Posted November 29, 2004 [size=1]I believe there is only bits and pieces of instructions so a full install thread will be valuable. [/size] Link to comment Share on other sites More sharing options...
