Kario Posted July 26, 2007 Share Posted July 26, 2007 Its making noise and I want to check if there is something I can do about it. I tried to remove it (3 screws at the bottom of the fan) but there is a thick wire bundle that goes just under the fan and it prevents me from puling it out. Link to comment Share on other sites More sharing options...
Osei Posted July 27, 2007 Share Posted July 27, 2007 if you are referring to the blower motor fan... Chilton's says the following: " remove the glove box.... remove the glove box panel..".....then what you've already done. It also suggests that you disable the air bags....that's up to you. hope this helps....find a chilron's... O. Link to comment Share on other sites More sharing options...
Kario Posted July 27, 2007 Author Share Posted July 27, 2007 I removed the glow box and unscrewed blowing fan. I cannot pull it out of its socket becouse there is a wire bundle in the way. I cannot bend it or disconnect it. Link to comment Share on other sites More sharing options...
Osei Posted July 29, 2007 Share Posted July 29, 2007 never having to remove one in a Subaru...I don't know what to tell you. PM either White Tiger or DTplacen, they are both Subaru Techs and they may be able to give you the info you need. O. Link to comment Share on other sites More sharing options...
