Mark34 Posted October 12, 2007 Share Posted October 12, 2007 I'm pretty sure I read that the KOS-V1000 will support factory LCD screens. You may want to check that out before buying the V500. Plus for the extra $150, the KOS-V1000 has 5 volt preouts, which will give a huge difference in overall sound quality. 5 Volts will provide a much cleaner sound output than the 2 volts from the KOS-V500. And if you're interested in nav only, you can get the LZ-702W screen from Kenwood which is the same size and touch screen controls and connect it to the KNA-G510 and not even use the A/V controller box, however I dont know how loud the screen's speaker will be in the dash for the voice guided navi. You might need to add an amplified speaker to make it louder. Link to comment Share on other sites More sharing options...
grbspecb Posted October 12, 2007 Share Posted October 12, 2007 it wont suport the touch screen part. they have a standard rca type cable that will hook u and then u use the remote that comes with the integration unit. that is a step backwards. from mhy understanding only one screen kenwood makes is comatible the 702 i beleive. kenwood said that also in a call to them Link to comment Share on other sites More sharing options...
Joon525 Posted October 12, 2007 Share Posted October 12, 2007 Here a link to the manual for the KOS-V500 for anyone who cares. http://inform2.kenwoodusa.com/manuals%5Ckos-v500.pdf Link to comment Share on other sites More sharing options...
Mark34 Posted October 30, 2007 Share Posted October 30, 2007 Still have to fill in the gaps and touch up the paint, but I don't think it came to bad.... I would like to thank Vincent for the help. http://i167.photobucket.com/albums/u151/marzario34/Picture001.jpg Link to comment Share on other sites More sharing options...
Leonardo Posted October 31, 2007 Share Posted October 31, 2007 Isn't glare during the day a problem? Vincent, think that if I purchase the controler and a beezle, your fab guy can copy your install? I REALLY like how it came out! Link to comment Share on other sites More sharing options...
Mark34 Posted November 6, 2007 Share Posted November 6, 2007 Actually, the glare isn't too bad. Even when there is some I can still read the screen easily. The only time I found the glare to be a problem is in the afternoon if I have the sunroof completely open, which for me isn't all that often. All I did was dremel out the clock location on the stock area and made a "U" bracket attached to the screen and then screwing it the a/c ducts. Then I masked off the screen and bondoed the gaps in and spray painted it a flat black. The black matches the factory color perfectly. However, I discovered that I suck at sanding and will have to try and even it out a little more with some more bondo. But I would say not too bad for my first attempt at doing this kind of body work. Link to comment Share on other sites More sharing options...
vr4Legacy Posted November 7, 2007 Share Posted November 7, 2007 So.. if I got ahold of a factory bezel for a Navi setup, would there be any dremeling involved, or would the upgraded screen fit right in? It sounds like they are the same size and all..... This is a very interesting upgrade option for me.... I too don't understand why Navi was only an option for Auto and Spec B.... don't think I would have paid the $1800 premium, but it would have been nice to have the choice. And looking at these options, it seems I can DIY for less and better..... hmmm.... Link to comment Share on other sites More sharing options...
