boostedsubbygt Posted July 22, 2007 Share Posted July 22, 2007 well i went to subaru the other day to get my oil changed and some of the tech noticed my belt was to tight so they loosed it. when they got done i drove my car to my wifes work then i notice as i pulled into the parking space i pressed my clucth and my car studdered and died mind my a/c was on full blast. so i took it back and they supposely fix it well three returns later it still did the same thing. anybody may have an idea the techs overlooked? Supposlty they tighting the belts and unpintched my vacuum lines and tighted my battery cables. my car is also still under warrenty too luckly Please help:confused: Link to comment Share on other sites More sharing options...
boostedsubbygt Posted July 22, 2007 Author Share Posted July 22, 2007 it seems to happen when my ac is on. it studders when clutch is engaged and sometimes dies. most of the time the rpm dropps to almost 0 then jumps back up Link to comment Share on other sites More sharing options...
Opie Posted July 23, 2007 Share Posted July 23, 2007 Is your steering wheel turned full ock when this occurs? Link to comment Share on other sites More sharing options...
jerami1981 Posted July 23, 2007 Share Posted July 23, 2007 One post says, when you press your clutch, the other says when it is engaged? If it is when the clutch is engaged, and the A/C is on is it stalling in first gear during take off, or under street legal speeds as in 20mph or higher? With the A/C on you need to give it a little more oomph so to speak when taking off from a stop or slow roll as the a/c is going to rob you of a few rpms. Since you said the rpms are dropping to 0 and shooting back up it just seems like you might be too close to stall speed. Are you new to manuals? Link to comment Share on other sites More sharing options...
boostedsubbygt Posted July 23, 2007 Author Share Posted July 23, 2007 no just new to turbo cars. it just happened with both the clutch pressed while pulling in a parking spot and going from a stop at a light while making a right turn. Link to comment Share on other sites More sharing options...
boostedsubbygt Posted July 23, 2007 Author Share Posted July 23, 2007 but it funny it didnt happen this mourning. maybe because its 70 degees instead of 100 yesterday. i ran the ac today too with no problem just to experiment Link to comment Share on other sites More sharing options...
jerami1981 Posted July 24, 2007 Share Posted July 24, 2007 maybe its just the clutch engagement points of this car that are getting you. this car supposedly has a very off color engagement point according to many people. Other than clutching issues i cant help with anymore ideas. Best of luck and i will continue to pop in and see whats comes about pr if anything else comes to mind with future developments. Link to comment Share on other sites More sharing options...
boostedsubbygt Posted July 26, 2007 Author Share Posted July 26, 2007 i took my car to subaru again and they found out the cooling fan relay senor they replays during the recall was faulty so they replaced that one and its all good thanks for all you guys help too. next stop HID KIT and exha ust LOL:cool: Link to comment Share on other sites More sharing options...
