dmiller5 Posted July 19, 2007 Share Posted July 19, 2007 Ok, so where did you guys mount your mobile dvd players? I can't decide. I have a 1/2din unit and nowhere in the front looks ok without major modification. I can obviously do a trunk thing but I would prefer not to. All ideas welcome. Thanks, Dan Link to comment Share on other sites More sharing options...
zmarko Posted July 20, 2007 Share Posted July 20, 2007 The only places I can think of, are 1) the glovebox, or 2) custom install in the armrest? Link to comment Share on other sites More sharing options...
dmiller5 Posted July 20, 2007 Author Share Posted July 20, 2007 both will not work Link to comment Share on other sites More sharing options...
zmarko Posted July 20, 2007 Share Posted July 20, 2007 both will not work Why? Link to comment Share on other sites More sharing options...
Repsak Posted July 20, 2007 Share Posted July 20, 2007 too small of spots. the glove box doesn't have enough depth. and the arm rest isn't long enough...i tried both. I just put it under the pass. seat. Link to comment Share on other sites More sharing options...
mikefoy6 Posted July 21, 2007 Share Posted July 21, 2007 +1 for under the pass seat! I even fit my power inverter under it too! Link to comment Share on other sites More sharing options...
fweasel Posted July 21, 2007 Share Posted July 21, 2007 Double din in the cubby FTW! too small of spots. the glove box doesn't have enough depth. . Sure it does. I've seen several pictures of single din install in the owners manual pocket. Sure, not all chassis are the same dimension, but a stand alone DVD is nothing exotic and relatively compact. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
dmiller5 Posted July 21, 2007 Author Share Posted July 21, 2007 ^^ I had to do some cutting of the plastic even with my 1/2din unit. It is a tight fit. Check it out: http://www.legacygt.com/forums/showthread.php?t=66661 Link to comment Share on other sites More sharing options...
fweasel Posted July 21, 2007 Share Posted July 21, 2007 ^^ I had to do some cutting of the plastic even with my 1/2din unit. It is a tight fit. Check it out: http://www.legacygt.com/forums/showthread.php?t=66661 Sure, nothing is ever just a "drop in" when it comes to audio in these cars. Trust me, I know all about cutting plastic to make things fit! ignore him, he'll go away. Link to comment Share on other sites More sharing options...
BMac1203 Posted July 22, 2007 Share Posted July 22, 2007 As do I. There's actually a decent amount of room to be had if you take out the manual's holder and look at it. It tapers in a few places for no reason. There's quite a bit of room behind the manual in that physical place. It loos like there's stuff in the way, but there really isn't too much. You should be able to get your unit in there (assuming it's really small). If not, you could try taking it outside of it's case, and making a custom enclosure/faceplate that would fit in the glovebox/manual spot. None of these options are easy perse (except for under the pass. seat), but do-able. Need a CarPC bezel? PM me! Link to comment Share on other sites More sharing options...
dmiller5 Posted July 23, 2007 Author Share Posted July 23, 2007 Yea that's what I ended up doing. http://www.imagestation.com/picture/sraid225/p5a4137d2dfb612bfd1ae855ca9b9e76e/e87b4404.jpghttp://www.imagestation.com/picture/sraid225/p5a4137d2dfb612bfd1ae855ca9b9e76e/e87b4404.jpg As do I. There's actually a decent amount of room to be had if you take out the manual's holder and look at it. It tapers in a few places for no reason. There's quite a bit of room behind the manual in that physical place. It loos like there's stuff in the way, but there really isn't too much. You should be able to get your unit in there (assuming it's really small). If not, you could try taking it outside of it's case, and making a custom enclosure/faceplate that would fit in the glovebox/manual spot. None of these options are easy perse (except for under the pass. seat), but do-able. Link to comment Share on other sites More sharing options...
SpecBee Posted July 25, 2007 Share Posted July 25, 2007 Dmiller, What Brand and model is your DVD player? Link to comment Share on other sites More sharing options...
mikefoy6 Posted July 26, 2007 Share Posted July 26, 2007 http://i144.photobucket.com/albums/r182/mikefoy6/IMG_0709.jpg Under the seat (aka ghetto fab) install FTW! Link to comment Share on other sites More sharing options...
