KRM Posted July 19, 2007 Share Posted July 19, 2007 has any one had the back up switch on a 5/mt go bad? my reverse lights stay on as soon as i shift into R. then they stay on until i park the car all night. (the fix is cheap and easy, i know.) thanks! Link to comment Share on other sites More sharing options...
groff Posted July 19, 2007 Share Posted July 19, 2007 might not be the switch, could be a short in the circuit somewhere too, i had that on my older durango, trailer wiring harness got spliced open on the road some and caused similar incident (just a heads up in case the new switch doesnt fix it ) Link to comment Share on other sites More sharing options...
deimos Posted July 19, 2007 Share Posted July 19, 2007 I assume you didnt accidentaly hit the "parking lights" switch on the steering wheel column? Link to comment Share on other sites More sharing options...
groff Posted July 19, 2007 Share Posted July 19, 2007 he said reverse lights though, not turn signals or brake lights or else i'd give ya this one Link to comment Share on other sites More sharing options...
pillboy Posted July 19, 2007 Share Posted July 19, 2007 My old Cherokee went through 3 back-up light switches which would cause this same problem when they failed. Finally wired the lights to a dash switch and just manually turned them on and off as I needed them. It is still ugly. Link to comment Share on other sites More sharing options...
