botbs Posted July 12, 2007 Share Posted July 12, 2007 http://www.discounttiredirect.com/direct/findWheelDetail.do?wd=19&pc=76564&rw=9&bp=5-100&tc=GGAWO2 Will +42 Fit our car??? I know +43 to + 45 will for 9" according to this forum..... If this fit, it is pretty good deal !!!! Link to comment Share on other sites More sharing options...
Hanger Posted July 12, 2007 Share Posted July 12, 2007 9.5" width... probably not... it haven't been done before... ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
BrownBoy Posted July 12, 2007 Share Posted July 12, 2007 9.5" width... probably not... it haven't been done before... it's 9" OP, It will probably "fit", but the only way to get them on would be to run alot of negative camber and run a really narrow tire, I'd say 225 at most. If you are lowered at all, you will need to not only roll the fender, but most probably need to pull it out a bit also. I personally would try to stick to a bit more offset, but it is indeed possible to get it under there... Link to comment Share on other sites More sharing options...
PGT Posted July 12, 2007 Share Posted July 12, 2007 the other issue is tire size....19's are pricey Link to comment Share on other sites More sharing options...
Hanger Posted July 12, 2007 Share Posted July 12, 2007 Genereal Exclaims UHP are not ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
BrownBoy Posted July 12, 2007 Share Posted July 12, 2007 Genereal Exclaims UHP are not Is General paying you to promote these? I hope not...because you spelled the brand name wrong... Link to comment Share on other sites More sharing options...
botbs Posted July 13, 2007 Author Share Posted July 13, 2007 Thanks guys!!! no hope =( Link to comment Share on other sites More sharing options...
Xenonk Posted July 13, 2007 Share Posted July 13, 2007 if you have coilovers it could fit, but you'll need to run some insane amounts of camber and run no wider than a short 245 tire. Keefe Link to comment Share on other sites More sharing options...
