JonLGT Posted July 7, 2007 Share Posted July 7, 2007 I have a set of Volk GT-Vs that are 2 piece that I want to take apart to have the lip re-polished and the hub re painted, my question is, does anybody know the torque specs, or know where I can get them for the bolts that hold the hub to the rim? Thanks in advance. -Jon Link to comment Share on other sites More sharing options...
mwiener2 Posted July 7, 2007 Share Posted July 7, 2007 most 2piece wheels are never meant to be taken apart. They permanently sealed at the factory. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
JonLGT Posted July 7, 2007 Author Share Posted July 7, 2007 These already have been taken apart, I am going to try to contatct the original owner who had them painted and see if he knows. Link to comment Share on other sites More sharing options...
mwiener2 Posted July 7, 2007 Share Posted July 7, 2007 if they've already been taken apart I would contact the manufacturer. They will probably want you to send them back to be rebuilt. They may not be safe as they are. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Joon525 Posted July 9, 2007 Share Posted July 9, 2007 I had my old Volks apart before. I had emailed Mackin asking the torque specs but this was years ago. I don't remember the specs being more than 25-30 lbs/in though. Just email or call Mackin and ask them, they'll know. From what I remember they were not permanently sealed either. I think sealing is only required on modular wheels where the lip and outer rim get separated. The Volk GT line of wheels has the outer rim as one continuous piece and the face as the only modular part. http://www.mackinindustries.com/ Link to comment Share on other sites More sharing options...
Waxiboy Posted July 10, 2007 Share Posted July 10, 2007 I used to have 3-piece Work wheels and there is a silicone seal between the inner and outer rim. On 2-piece wheels, I doubt if you need to seal them as the rim is 1 piece and should hold air independently. Link to comment Share on other sites More sharing options...
axis008 Posted July 10, 2007 Share Posted July 10, 2007 Yeah as Joon mentioned, I suggest contacting Mackin. -ben Link to comment Share on other sites More sharing options...
Xenonk Posted July 10, 2007 Share Posted July 10, 2007 what size are the bolts and threads? you can determine the torque specs based off of the sizing (there's a build standard to them and the design specification that you can look up online without too much of a problem). Just dont bolt them on around the rim.. you should torque the bolts as if you were to do a star pattern or cross lip fashion to have the bolts all go in evenly. Keefe Link to comment Share on other sites More sharing options...
Nickz31se-r Posted September 12, 2008 Share Posted September 12, 2008 anyone ever find out? I need to put my wheels back together . Link to comment Share on other sites More sharing options...
JonLGT Posted September 13, 2008 Author Share Posted September 13, 2008 Sorry, I never got an answer either. Link to comment Share on other sites More sharing options...
mwiener2 Posted September 13, 2008 Share Posted September 13, 2008 why are you guys takin your wheels apart in the first place? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Nickz31se-r Posted September 13, 2008 Share Posted September 13, 2008 to paint them Link to comment Share on other sites More sharing options...
Nickz31se-r Posted September 13, 2008 Share Posted September 13, 2008 took my time at about 40 minutes per wheel and went around in a standard torquing sequence and everything seems to be good I also used blue thread lock and when a ran out used the red that I had lying around. I would use the blue over the red, as the red seemed to harden up to quickly as I needed to torque 20 nuts and bolts about 6 times each until finished. Link to comment Share on other sites More sharing options...
