jikhead Posted June 21, 2007 Share Posted June 21, 2007 I found some useful information at tirerack while looking at wheels for the Spec B. Your vehicle is equipped with a tire pressure monitoring system that requires a sensor to be installed in the tire and wheel assembly for proper operation. NOTE: The original sensors from your original wheels can be used or you may purchase sensors from The Tire Rack. INSTALLATION: If you purchase a Tire & Wheel Package when you buy new sensors, the sensors will be installed on the wheels at no additional charge. Otherwise, you will have to arrange for installation by a trained technician after your new wheels are shipped to you. The Tire Rack's Recommended Installers are available to help you with your installation needs and can be selected by ZIP Code in the shopping cart. Once installed, you will need to read your vehicle's owner's manual to review the proper procedure for allowing your vehicle to "recognize" the new sensors. Your system includes: TPMS SENSOR $152.00 for a quantity of 4 TPMS NUT $8.00 for a quantity of 4 Total Price: $160.00 There is a picture of what the sensor looks like http://www.tirerack.com/wheels/TPMSS...ModClar=Spec+B Link to comment Share on other sites More sharing options...
BigInALegacy Posted June 26, 2007 Share Posted June 26, 2007 So if I get rims I either have to buy these installed, or find someone who knows how to reinstall my stock TPMS on the new rims? If I plan on using my stockers in the snow I'm probably just better off having them install new ones on the rims otherwise I'd have to keep changing them with the rims... is that correct? Link to comment Share on other sites More sharing options...
KA81 Posted June 26, 2007 Share Posted June 26, 2007 or keep an eye on your tire pressure and ignore the damn TPMS light/warning Link to comment Share on other sites More sharing options...
rudy Posted June 26, 2007 Share Posted June 26, 2007 Or remove the TPMS box from under the driver's seat. Link to comment Share on other sites More sharing options...
DrJayMixwell Posted June 26, 2007 Share Posted June 26, 2007 INSTALLATION: If you purchase a Tire & Wheel Package when you buy new sensors, the sensors will be installed on the wheels at no additional charge. don't be fooled into having to buy these again. the ones on the stock rims can be used again. and where ever you get your tires mounted and installed should do it for free. takes like 2 minutes. Link to comment Share on other sites More sharing options...
BigInALegacy Posted June 26, 2007 Share Posted June 26, 2007 So if i buy rims and want to keep my TPMS on the stockers... and i buy a new TPMS for the rims, the shop that mounts them shouldnt charge me anything to install them (or very little)? Link to comment Share on other sites More sharing options...
str8dwn Posted June 26, 2007 Share Posted June 26, 2007 Are most wheels accepting of the TPMS or do they have to be designed for them? I am looking at a slightly older set of wheels that I have concerns about. Link to comment Share on other sites More sharing options...
ilh Posted June 26, 2007 Share Posted June 26, 2007 I thought someone here said the BBS RKs they bought would not accept the TPMS modules due to some clearance issues. Link to comment Share on other sites More sharing options...
kenchan Posted June 26, 2007 Share Posted June 26, 2007 Im a regular shopper over at the TireRack and they took care of an issue i had on a new pair of tires... just wanted to share my great experience with TR. not for my Legacy, but still, would've been the same experience. http://www.northamericanmotoring.com/forums/showthread.php?t=105286 Link to comment Share on other sites More sharing options...
eddiemoney Posted June 27, 2007 Share Posted June 27, 2007 So I read that the computer has to learn the sensors. . . . .So i couldn't have two distinct sets of wheels/tires with sensors? Link to comment Share on other sites More sharing options...
rudy Posted July 2, 2007 Share Posted July 2, 2007 I thought someone here said the BBS RKs they bought would not accept the TPMS modules due to some clearance issues. That's me. Hence why the TPMS box is going to be removed some weekend Link to comment Share on other sites More sharing options...
red beast Posted July 4, 2007 Share Posted July 4, 2007 Photo shown may not match actual sensor. thats not what they look like $160 for 4 is a very good price http://img.villagephotos.com/p/2003-10/423426/tpm.jpg Link to comment Share on other sites More sharing options...
edkwon Posted July 4, 2007 Share Posted July 4, 2007 I just ignore that stupid light, i'm always adjusting my tire pressures with temp variations anyway and keep a good tire pressure gauge in my car Link to comment Share on other sites More sharing options...
keysersoze Posted July 22, 2007 Share Posted July 22, 2007 I found some useful information at tirerack while looking at wheels for the Spec B. Your vehicle ...... Your system includes: TPMS SENSOR $152.00 for a quantity of 4 TPMS NUT $8.00 for a quantity of 4 Total Price: $160.00 There is a picture of what the sensor looks like http://www.tirerack.com/wheels/TPMSS...ModClar=Spec+B Is anybody using the sensors from Tire Rack? Definately cheaper than ordering them from Subaru. Link to comment Share on other sites More sharing options...
BigInALegacy Posted July 22, 2007 Share Posted July 22, 2007 I plan on it once I pick out the rims I want... the last 2 sets of rims I picked were 'unavailable' for 6-8wks, or discontinued.... Link to comment Share on other sites More sharing options...
rao741 Posted July 27, 2007 Share Posted July 27, 2007 so if purchased will these sensor work with stock system???????looking into this myslef rao741 Link to comment Share on other sites More sharing options...
BigInALegacy Posted July 27, 2007 Share Posted July 27, 2007 If you tell tirerack your vehicle they should give you the correct sensors. From my understanding, you then have to go to your dealership and have them "married" to your car so it recognizes them and the (!) light goes off. Link to comment Share on other sites More sharing options...
