clevere1 Posted June 18, 2007 Share Posted June 18, 2007 Hey guys, I got a belt that is smelling like it's burning. So I'm going to replace all the belts, but I was wondering, does anyone have the correct procedure for belt tension on a 2001 Legacy outback with the 2.5? Thanks in advance. Link to comment Share on other sites More sharing options...
Osei Posted June 26, 2007 Share Posted June 26, 2007 From Chilton's ... "The tension of each belt is checked by pushing on the belt at a distance halfway between the pulleys. Push firmly with your thumb and see how much the belt moves (deflects). As a rule of thumb the belt should deflect approximately 1/4 inch." Basically the same for most engines. O. Link to comment Share on other sites More sharing options...
