Mr. CentralOhioSubarus Posted June 19, 2007 Share Posted June 19, 2007 Don't spray water in your door. Silicone spray should only be used on the visible weather stripping, not down in the door. If the problem gets really bad the only option is to pop the door frame out and check the window track, adjust it and grease with white lithium grease. I don't trust dealerships. They usually don't fix the problem and create three more. not really sure how to do that....I sprayed it in the channel...I can't fit a rag in there and my fingers are too fat anyway... maybe spray some hose water down there? the dealer is a last choice scenario seeing as how they are 40min from my house and the mileage to/from is just a bear on my lease Link to comment Share on other sites More sharing options...
NYCBRED Posted June 19, 2007 Author Share Posted June 19, 2007 Don't spray water in your door. Silicone spray should only be used on the visible weather stripping, not down in the door. If the problem gets really bad the only option is to pop the door frame out and check the window track, adjust it and grease with white lithium grease. I don't trust dealerships. They usually don't fix the problem and create three more. well I sprayed it in the door (in between the molding and window glass) and now not only do I have the same stupid noise but everytime I roll the window down and then up, I get the crap on my glass...so I've been reduced to carrying a can of Stoner's Invisible Glass and an MF towel with me... my first and last subaru this will be.....FUK SOA!!! Link to comment Share on other sites More sharing options...
LongHiway Posted June 19, 2007 Share Posted June 19, 2007 Give the car a better chance, it's a better car than squeeking glass. I just had my last check-in before the warranty was up. Not much needed but, the dealer was very willing so, I'd say they will fix you door & window issue. Link to comment Share on other sites More sharing options...
Leonardo Posted January 25, 2012 Share Posted January 25, 2012 Bumping this to see if there is a newer approach to this issue. Link to comment Share on other sites More sharing options...
ibr_adam09 Posted January 25, 2012 Share Posted January 25, 2012 ear plugs ? Mine doesn't squeak, thank god... knock on wood. Link to comment Share on other sites More sharing options...
Drogos Posted January 25, 2012 Share Posted January 25, 2012 mine rattles, seems of track or something. Anyone has fix for that? Link to comment Share on other sites More sharing options...
ColdBore Posted January 26, 2012 Share Posted January 26, 2012 My mustang does it, not my lgt..yet Link to comment Share on other sites More sharing options...
jhawk222 Posted January 26, 2012 Share Posted January 26, 2012 My front two windows used to squeak......removed my tint and the noise disappeared. Link to comment Share on other sites More sharing options...
Leonardo Posted January 26, 2012 Share Posted January 26, 2012 No tint here! :-/ Link to comment Share on other sites More sharing options...
Alfred_Buchi Posted January 27, 2012 Share Posted January 27, 2012 My drivers window switch is really hard to push. No squeals though. Link to comment Share on other sites More sharing options...
