Piripi Posted May 22, 2007 Share Posted May 22, 2007 Hello I was wondering if i could raise the car above stock height with coilovers?? which one would raise it more. We go hiking very often and sometimes, well everytime we touch with some stone or branch. I was also thinking in getting some whatever rims with a tough tire for peace of mind. Maybe some outback wheels and tires. The woman doesnt want an Outback for everyday driving so im looking for options for those dirt days. Cheers Link to comment Share on other sites More sharing options...
mwiener2 Posted May 22, 2007 Share Posted May 22, 2007 shoulda gotten an outback mine handles as well if not better than a stock GT and I straddle cones at the Autocross to shave time My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
urfsin Posted May 22, 2007 Share Posted May 22, 2007 You can get the Megan Racing Outback specific coilovers. They will fit an LGT just fine. With these you can have stock LGT height or you can raise your height to Stock OB height. Slide It Sideways Link to comment Share on other sites More sharing options...
NSFW Posted May 22, 2007 Share Posted May 22, 2007 Is it actually practical to adjust ride height with coilovers in the morning and evening on a day when you're going to hike? I've never owned a set, but I kinda assumed it would take hours, not minutes, to raise and lower the car. Am I right or am I wrong? Is there any room to use the adjustment wrench while the coilovers are on the car? Link to comment Share on other sites More sharing options...
CreoSTi Posted May 22, 2007 Share Posted May 22, 2007 Is it actually practical to adjust ride height with coilovers in the morning and evening on a day when you're going to hike? I'm on the side that it wouldn't be very practical, as it does take a bit of time. The ride height on my coilovers was adjusted while they were installed on the car, but it's not something I would want to do often. But, since the o.p. will also be switching wheels each time, my definition of "practical" might be different. -Mike- Link to comment Share on other sites More sharing options...
Boostjunkie Posted May 22, 2007 Share Posted May 22, 2007 Is it actually practical to adjust ride height with coilovers in the morning and evening on a day when you're going to hike? I've never owned a set, but I kinda assumed it would take hours, not minutes, to raise and lower the car. Am I right or am I wrong? Is there any room to use the adjustment wrench while the coilovers are on the car? It only takes about 45 minutes to adjust the ride height at all 4 corners. Not super quick, but easy to do and not too time consuming. Link to comment Share on other sites More sharing options...
Piripi Posted May 23, 2007 Author Share Posted May 23, 2007 thanks a lot. I found a set of wheels 16 inch with a big sidewall, that should help a lot. I'll be looking for coilovers too. She should of gotten an Outback i know. I could not convince her to get the Outback. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted May 23, 2007 Share Posted May 23, 2007 I didn't think 16 inch rims would fit over the front brakes. Link to comment Share on other sites More sharing options...
RobE Posted May 23, 2007 Share Posted May 23, 2007 16 inchers wont clear the brakes http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
Guest Posted May 23, 2007 Share Posted May 23, 2007 It only takes about 45 minutes to adjust the ride height at all 4 corners. Not super quick, but easy to do and not too time consuming. C'mon... not after they get rusted and all.... It would be much faster to swap the entire suspension. It's an hour after you get hang of it Anyway good bye wheel alignment each time. Link to comment Share on other sites More sharing options...
BOXRPWR Posted May 23, 2007 Share Posted May 23, 2007 put it on bags man. fffffffffffffffff (up)..........t-shhhhhhhhhhhhh (down) then you can adjust the suspension in seconds Link to comment Share on other sites More sharing options...
CreoSTi Posted May 23, 2007 Share Posted May 23, 2007 put it on bags man. -Mike- Link to comment Share on other sites More sharing options...
Piripi Posted May 24, 2007 Author Share Posted May 24, 2007 hmmm i guess i have to say bye bye to those cheap 16's. Im going to try get some 17 with a tall side wall to be able go a little more confortably on dirt roads, i dont care for speedo. And i will go from there. Link to comment Share on other sites More sharing options...
